Nelson's KZ1000 Fighter? build
- Nelson
Re: Nelson's KZ1000 Fighter? build
21 Dec 2012 02:15 - 21 Dec 2012 02:16
I think I found a free way to get nice, new-looking bolts for the valve cover. The cam cap bolts appear to be exactly the same, but of course they are clean and nice! I'll swap them with the ugly ones on the outside
Attachment valvebolts.jpg not found
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
Last edit: 21 Dec 2012 02:16 by Nelson.
- Nelson
21 Dec 2012 02:18
Got some more bits cleaned up and painted
Attachment caliper.jpg not found
- Nelson
21 Dec 2012 02:20
Hey wireman, that place has the cool anodized bolts, but only in small sizes. 5mm is biggest dia they have
- wireman
21 Dec 2012 12:57
They might stock other sizes,Im not sure.
The main problem Id have with aluminum bolts on engine parts other than corrosion would be bolt stretch.
When the clutch cover/valve cover and dyno cover are bolted down to the engine cases Id be willing to bet they add a lot of rigidity to the engine cases,especially the clutch cover and valve cover.
If those aluminum bolts stretch there goes the rigidity ,and I id also be afraid of oil leaks caused by the covers moving.
Just a thought
Just a thought
- racer54
21 Dec 2012 13:37
I may be wrong on this but it has always been my understanding that the valve cover bolts and cam cap bolts are different in hardness. The cam cap bolts are a higher grade bolt beings they are under stress...anyone know for sure? I was always told not to use valve cover bolts in cam caps.
- wireman
21 Dec 2012 14:36Attachment Image_2012-12-21.gif not found
According to this picture theyre the same bolt on the 77-78 kz1000 anyway,although Ive seen different style cam cap bolts on some of the 79-80 motors Ive had.
I prefer to install longer hardened bolts myself,though it may be over kill
- 4TheKZ1000
21 Dec 2012 14:56racer54 wrote: I may be wrong on this but it has always been my understanding that the valve cover bolts and cam cap bolts are different in hardness. The cam cap bolts are a higher grade bolt beings they are under stress...anyone know for sure? I was always told not to use valve cover bolts in cam caps.
Some of the engine rebuild shops use grade 8 bolts on cam caps.....kinda strange when torque values are so low??? never understood that.... :huh:
- Nelson
21 Dec 2012 17:05
Thanks for the bolt research guys. They do look exactly the same.
- SBK Racer
21 Dec 2012 17:06
Nelson,
I like what you have done so far...
If you went with the 2 piston SV650 front calipers, could you have gone with the 4 piston SV1000 front calipers...
How is the braking power on such heavy bike?
Luis
Luis
MOTORCYCLES ARE DANGEROUSLY FUN!!!
A good street rider uses judgment, to avoid situations that require superior skill...
A good track rider uses superior skill, to seek situations that define their judgment...
1998 KZ1000P-17 - 2004 PW80 Pit Bike - 2005 SV650R - 2006 SV650 - 2006 GSXR750 - Soon day...
- Nelson
21 Dec 2012 23:06
Nope. The wider calipers would hit the spokes. I owned an SV1000 at the time and I did some measuring. I don't think any type of caliper with pistons on the inside would fit that wheel.
The 650 front brake works VERY well. It's almost too strong for the amount of traction the small stock tire has. I really like it.
The rear is from a hayabusa, but I think it's the same caliper as many Suzukis. It was feeling a bit mushy before I took it apart, but probably just needed bleeding.
- Nelson
21 Dec 2012 23:10 - 21 Dec 2012 23:12wireman wrote: They might stock other sizes,Im not sure.
Just a thought
Thanks. I had thought about that a little, but not as much as you did :lol:
Titanium bolts would solve the problem, but I've been looking for those also and no luck so far. I need 6x1x25mm. 9 of them
I may just get regular stainless steel (not red), which is cool too, but not what I wanted.
Last edit: 21 Dec 2012 23:12 by Nelson.
- SBK Racer
21 Dec 2012 23:23 - 21 Dec 2012 23:24
And did you run custom brackets?
Any pictures?
Also what master cylinder are you using?
Thanks, Luis
Any pictures?
Thanks, Luis
Last edit: 21 Dec 2012 23:24 by SBK Racer.
