Nelson's KZ1000 Fighter? build
  • rokit_armor
  • rokit_armor's Avatar
Re: Nelson's KZ1000 Fighter? build
01 Jan 2015 03:44
#657501
What I do when doing a precise cut with the vinyl fine-line tape is to leave the end a bit long, 4-5", place a razor blade on top of the tape where you want to make the cut, and pull the tape against the blade instead of pushing the blade into the tape. Don't apply too much pressure to the blade and make sure it's nice and sharp!
The following user(s) said Thank You: Nelson
  • Nelson
  • Nelson's Avatar Topic Author
01 Jan 2015 09:01
#657514
good tip! thanks!
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
  • Nelson
04 Jan 2015 18:00
#657786
kaw-a-holic wrote: What kind of tape are you using? Napa carries good pin stripping tape. Ask the guys at Napa paint shop what they would do and what paint they recommend. I can't wait to see your finished product. It's going to be a cool paint job.
The orange tape is vinyl, seems ok although it sometimes doesnt' stick super well on the bends. The yellow tape cost 2x as much and hardly bends at all. I don't know why anyone would want it... a waste of $ :(
Attachment P1070632.jpg not found
  • Nelson
04 Jan 2015 18:04 - 04 Jan 2015 18:09
#657787
I did more masking of the pinstripes and did a test also. Heres the test
Attachment P1070628.jpg not found
Top line has 2 coats, bottom has 1. 2 is definitely better. There are some slightly rough edges which is making me rather concerned about doing this. I don't want to mess up all the paint I did underneath the pinstripes! Click the pic to make it bigger and u can see the roughness I think.
Attachment P1070629.jpg not found
I'm thinking maybe I should look into a tape-on stripe that can be clearcoated. Anybody know of tape like that?
Last edit: 04 Jan 2015 18:09 by Nelson.
  • Nelson
04 Jan 2015 18:06
#657788
here's more of the masking.
Attachment P1070627.jpg not found
Attachment P1070630.jpg not found
  • Nelson
04 Jan 2015 18:08 - 04 Jan 2015 18:17
#657789
The masking is done but I'm nervous about putting the paint on. I really don't want a bunch of rough edges... :pinch: Maybe I need more tests first.
I'm researching pinstripe tapes. There's plenty available, but I don't know if they will make such sharp bends.
Last edit: 04 Jan 2015 18:17 by Nelson.
  • ramtough_63
  • ramtough_63's Avatar
04 Jan 2015 19:36
#657798
3m blue fine line vinyl 1/16" for super tight turns 1/8" probably be small enough for it all 1/4" to back it up just because
clear sand reclear til edges are gone
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
  • Nelson
04 Jan 2015 21:27
#657811
are you saying to shoot clear on top of the rough edged pinstripes and then sand?
  • ramtough_63
05 Jan 2015 17:33
#657867
after art work Clear then block sand and re-clear to eliminate the hardline ridge sometimes a couple times if needed
I have also seen guys who use a midcoat clear to protect each layer before adding additional artwork (stripes)
incase it stinks they can sand back to the before and tryagain
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • Nelson
05 Jan 2015 21:54 - 05 Jan 2015 21:55
#657883
I see, thanks. That's a clever way to do it.
I just found some 1/8 white vinyl pinstripe tape to experiment with. Seems pretty flexible. This may be my best solution. We shall see. I need to do some tests. Pics to come.
Last edit: 05 Jan 2015 21:55 by Nelson.
  • ramtough_63
06 Jan 2015 10:08
#657905
good luck looking forward to the pics
I haven't had anytime to do any painting the last year or so but I still keep up with a couple custom painters
and am still learning the guys from the local paint supply can be a wealth of info but they are giving advice for
blending panels & general painting rules that custom paint(ers) throw(s) completely out the window.
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • Nelson
07 Feb 2015 20:11
#660880
I did a lot of pinstripe practicing with paint, masking, and vinyl tape. I decided to go with the vinyl pinstripe tape.
Here it is with clear on top.
Attachment P1070646.jpg not found
Looks great from a few feet away, but what you cant' see is the rough surface. This kinda shows it.
Attachment P1070650.jpg not found
