Project 81 KZ11R
  • jydog
  • jydog's Avatar Topic Author
Re: Project 81 KZ11R
06 Jan 2012 07:56
#496674
Thanks Leon, I was going to get her a shirt that said " if you are reading this, the bastard fell off". I hear they make a few bobber kits for these bikes as well. She is doing pretty well riding it in the neighborhood, shifting gears and such. Of the three times she rode it only had one mishap at the end of the driveway stopping. I had to help her pick it up and she got right back on and started riding.
81 KZ1000 LTD
Griffin GA
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
06 Jan 2012 10:51 - 06 Jan 2012 10:51
#496688
cool.
i hope she keeps liking it.
they seem to be a fairly popular bike.
the bastard fell off,would be a good one :laugh: !
Last edit: 06 Jan 2012 10:51 by 531blackbanshee.
  • jydog
06 Jan 2012 13:57
#496717
Ceramic coated my old rusty headers. Not bad for $125 huh. Now I just need to find a shor 2 1/2 baffle to go inside the pipe
81 KZ1000 LTD
Griffin GA
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
07 Jan 2012 16:42
#496927
kerker has a 2 1/2" collector. i have a spare.
check my header thread for more options.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • ramtough_63
  • ramtough_63's Avatar
07 Jan 2012 17:21
#496931
back in the day they took an oil filter that fit and took the casing off to fool the cops lol
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • jydog
29 Jan 2012 17:54 - 29 Jan 2012 18:20
#500693
Started on some rear brakes. Ive never seen this done before. Hope it works. :huh: Mark im looking for your header thread. ramtough_63 that sounds like it will work in a pinch. March is closing fast. I've got to get this thing ready to do at least 250 miles back from Panama City Beach FLA.
81 KZ1000 LTD
Griffin GA
Last edit: 29 Jan 2012 18:20 by jydog.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
29 Jan 2012 20:00 - 29 Jan 2012 22:39
#500736
i just looked through it, but its mostly just pics of headers.
kzrider.com/forum/2-engine/271747-header-pics
do u have the slip on ? what kind of pipe is that? is the od of the tail 2.5" ?
i use a 2" baffle for my 1200cc motor.
a 1.5" would be better. the bigger u go the torque curve will be higher.
i just bought a perferated sleeve from a Harley shop, and modified it to fit in my kerker tail piece. took a grinder to the kerker end cap. it had 1 1/4" hole i think. ground the caps end until the hole was the same size as the new inner.then had them welded together.
Attachment 20090514213215.jpg not found
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 29 Jan 2012 22:39 by mark1122.
  • jydog
31 Jan 2012 08:34 - 31 Jan 2012 08:39
#501051
Mark, I dont have the slip on for this pipe but I do have one for a yoshi. I might see if I can get that to fit.
Well I got the bike back on the road with carbs today since my efi ecu is acting up and that will be on hold until after the relay run. First drive with the gpz motor and I notice it falls flat from 3k rpm up. Definitly needs jets. The second thing I notice is that noise is back. Your not going to belive this but I look down while riding and notice the chain is bouncing off the frame going back and forth. Not hitting the frame on the top but from the bottom where it has a conflect with one of the bolts holding my footpeg on. Probably not a common problem since Im running a 5/8 offset sprocket. So sawsall time and problem fixed. Man I feel stupid. Riding it a second time I noticed another sound as the bike speeds up. Looks like a warped rotor. I'll fix that one later. Im making that relay run if I have to push this thing.
Found a good deal on a couple of helmets and orderd my son and I a set that match.
81 KZ1000 LTD
Griffin GA
Last edit: 31 Jan 2012 08:39 by jydog.
  • 531blackbanshee
  • Vendor
  • Vendor
31 Jan 2012 12:04
#501075
bike looks tuff!
i have been watching bell comeback and wondering how there helmets were in comparison to current offerings.
i really like the look of the helmet you posted.does the whole front flip up,or the shield can flip up to?
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
31 Jan 2012 13:34
#501085
i have had both of those problems as well. i ground off the inner footpeg boss, and i run a roller under the chain too. i have straightened disks, on the bike. i used a dial indicator, a 2x2 and a hammer. its still straight. :)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • jydog
04 Feb 2012 17:14
#502028
Mark1112, that takes some skill.. 2x2 and a hammer ha ha..
Leon, the whole front tips up and the shield and is has some shades built in like a fighter pilot.
Big helment though. Makes the rest of your body look small.
Ok, I've been trying on some new body parts... older gpz stuff. I am definitly going to find a way to make the tale fit. Not sure about the tank even though it has everyting I need for EFI. It crazy how much the shape and even the color changes the look of a bike. Oh, and the pipe is staying also, I just lucked out that it follows the lines of the bike.
81 KZ1000 LTD
Griffin GA
  • 531blackbanshee
  • Vendor
  • Vendor
07 Feb 2012 12:08
#502557
the gpz tank looks more aggresive.
i would like to see the tail piece with the gpz tank :whistle: .
