Modified KZ1000 Hopefully a knee-dragger project.
- Calhoun
- Hayabusa= I ride to the strip club in flip flops
Re: Modified KZ1000 Hopefully a knee-dragger project.
25 May 2009 17:03 - 25 May 2009 17:04
80 IT175, 84 XL200, XT250, 95 ST1100 96 xr650l (30k miles),kz1000, KX250 97'
Last and most important 93 KX500.
Last edit: 25 May 2009 17:04 by Calhoun.
- mark1122
- Keep twisting it
25 May 2009 17:20 - 25 May 2009 17:25
I meant ,is this your only bike to ride? what do u mean, a 32" for the rear. how is that posible? are u planing on runnig the rear cal from the front master?lol.
I have the same arm with a 24" line going under the arm.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 25 May 2009 17:25 by mark1122.
- jordan
25 May 2009 17:30
Calhoun wrote:
NICE
NICE
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- Calhoun
26 May 2009 03:23
That's funny Mark, Run it from the front...:laugh: Hey I could have "Linked Braking":woohoo: It is a long distance. because I'm not running rear sets.
- Calhoun
31 May 2009 19:17 - 31 May 2009 20:43
Gearing update............
I bought one of those new "Super bike" front brake line kits from Galfer. It's the two line kit for running lines straight from the master cylinder , to the calipers.It's for an 07' Yamaha R1. The longer of the two lines is 30 inches. I used it on the rear. It turned out o.k. even without a 90' bend for the master cylinder.I put a hold down on it on the back of the swingarm tube.(you can't see it)
So now I have rear brakes and put the old rotor and pads on and went for a ride. I still don't have front brakes just yet.
Any way the gearing is rather low. I was in 5th gear putting around in the 'hood. Maybe I could do some side work as a stump puller.
I goosed it once and spun the
ecentric adjuster on the left side. Too much torque and a heavy bike zipping across a freshly paved street.
I will have to find the proper torque for the clamping bolts.:blush:
The gearing is 17/45 with a 530 chain.
Vortex offers a 41. Jt has a 42. I will try the aluminum Vortex 41 tooth and if that is not "high" enough I will put an 18 or 19 on the front. I have a feeling that I will have to change the front anyway.
Last edit: 31 May 2009 20:43 by Calhoun.
- Calhoun
31 May 2009 19:21 - 31 May 2009 19:29
Last edit: 31 May 2009 19:29 by Calhoun.
- PLUMMEN
31 May 2009 19:43
looking good!
- Calhoun
31 May 2009 19:48
Larrys' new V-Max has gone off to motorcycle heaven.!!!
Some broad squished him and his bike into the back of a car. His o.k. .. Trying to get paid I think. I didn't even get to ride it.:lol: :lol:
- mark1122
- Keep twisting it
31 May 2009 20:05
On a 630 1 tooth at the front = about 2.5 teeth at the back. u may want to find out what speed it cruises at on the highway before u order a sprocket. u can do some math, or look it up on a chart, to find how many teeth to change, to get where u want.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Calhoun
02 Jun 2009 17:06
I will have to calibrate my Vapor and see what my speed is. there is a screen I have to toggle to and input a value after I use an equasion they have given me in my manual.
- tachrev
- Rubber Side Goes Down
03 Jun 2009 04:48
Calhoun wrote:
Damn that must feel weird to have happen while riding it.
Coming right along, looks good.
ecentric adjuster on the left side. Too much torque and a heavy bike zipping across a freshly paved street.I will have to find the proper torque for the clamping bolts.:blush:
Build Thread
Build Thread
- Bdog
- Sweep the leg johnny!!!
03 Jun 2009 09:18
What part of the cush drive did you machine, the sprocket face or the inside where the rubbers are? I have always wondered this. Thanks
Brandon
Brandon
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
