Modified KZ1000 Hopefully a knee-dragger project.
- Bad Kaw
- Flying Squirell
Re: Modified KZ1000 Hopefully a knee-dragger project.
22 Apr 2009 21:20
Yup. Got mine from DG; can't remember the price b/c it came with the bearing support plate and I got it as a 'kit'. But as I recall it was all very reasonable.
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- Old Man Rock
23 Apr 2009 04:41
american classix has both 530 & 630 1/2" offsets...
Thy're ~ $85 plus shipping but are worth it... Extremely well made, one piece design machined...
NOTE: @ 1/2", chain clears frame!
americanclassix.com/kawa_improvements.html
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- mark1122
- Keep twisting it
23 Apr 2009 06:31
PMF has 630 x 1/2" , 5/8" $80/ $60
www.pmfronline.com/counter_shaft_sprockets.htm
Pingle $60
www.pingelonline.com/offset_countershaft_sprockets.htm
Schnitz $90
secure.mycart.net/catalogs/catalog.asp?catid=2486&prodid=328632
Pingle $60
Schnitz $90
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Calhoun
- Hayabusa= I ride to the strip club in flip flops
24 Apr 2009 19:03
I guess I will have to call Sprocket specialties and try to get one of these.tk11b40 wrote:
80 IT175, 84 XL200, XT250, 95 ST1100 96 xr650l (30k miles),kz1000, KX250 97'
Last and most important 93 KX500.
- tk11b40
24 Apr 2009 22:23
Hey maybe I was a bit innaccurate. The rear came from Sprocket specialist, the countersprocker, I think I ordered that from Kosman, when I bought the gusset kit.
I am surprised at the response you got, they were very helpful on the rear sprocket. I would try again. But reading all these post's is cool because I have not heard of a few of these companies. More is always better!!
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- Calhoun
25 Apr 2009 07:48
- Calhoun
25 Apr 2009 07:51
I plan to put the side flappy things in a vise and bend the so that they are straight down. Then I can get a couple pieces of flat and mount it. Cool!!
- Calhoun
25 Apr 2009 07:56
I took the bolt on section out of the mystery exhaust to make it shorter. Then I made a pie cut and welded it back at an angle in order to clear the swingarm.It is also angled up a little for clearance for when I'm trying to drag a knee.:silly: I am still trying to get used to it.I still need to mountit below the brake pedal.
- Calhoun
25 Apr 2009 07:59
But you can also see the wheel and swingarm with it shorter.
It sticks out a little. Maybe I'll put a 90' elbow in it and point it straight out the left side. HMMM:dry:
- Calhoun
25 Apr 2009 08:02
Oh here is the other stuff I did. Mounted the rear master cylinder and side cover mount. Modified the stock pedal.
I plan to learn to tig weld and then redo the whole bike.
I am way out of practice and my welds are fugly. They do have good penetration though.
- mark1122
- Keep twisting it
27 Apr 2009 07:13
I see that u rebushed to use the ZRX swing arm axle. that must have been a challenge to get the bore lined up straight.
Well done.
Where did u get the fender? Kossman?
Well done.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
27 Apr 2009 08:30
Calhoun wrote:
youve got my attention!
