Modified KZ1000 Hopefully a knee-dragger project.
- Calhoun
- Hayabusa= I ride to the strip club in flip flops
Re: Modified KZ1000 Hopefully a knee-dragger project.
16 Apr 2009 14:36
I would like a little more speed at a lower rpm. Opposite of gearing it lower.
80 IT175, 84 XL200, XT250, 95 ST1100 96 xr650l (30k miles),kz1000, KX250 97'
Last and most important 93 KX500.
- mark1122
- Keep twisting it
16 Apr 2009 14:46
Then this 37 tooth aluminum sprocket i have may serve u well. its like new.it will bolt right onto the zrx hub. it has a depression on 1 side, so u could flip over it to change the chain clearance.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- tk11b40
16 Apr 2009 21:00 - 16 Apr 2009 21:10
16 tooth counter sprocket
40 tooth rear sprocket
180/55 17 inch rear tire
Min Max At Power
Gear MPH MPH MPH
1st: 0 51 42
2nd: 18 74 61
3rd: 23 98 80
4th: 28 118 97
5th: 31 134 110
I calculated my gearing on the web site, max rpms 8500.
I know from riding the naked bikes that you need alot more horsepower to pull from say 110 mph to 135 mph.
I ride a Ducati Monster on the track, 148 indicated on the speedo is about as fast as I have seen. Thats the speedo mind you I'm trying to look at it as I approach the "Dogleg" after the front stretch of the Reno Fernley raceway. Ahhhts a littel scary there, your lookin at that dogleg and praying you make it through.
The monster has 120 Horsepower. The stock KZ has about 90, and a much larger frontal area, so just guessing I would say you need about 140 Horsepower to get the KZ to 140 plus.
I set mine up for 110 mph. I know it will get there, and I have no need to ride the street any faster. At redline the chart says it will hit 134, but I would be surprised if it got to that speed. It will be quick, and hit a pretty good top speed.
Hope this helps.
Ted
Min Max At Power
Gear MPH MPH MPH
1st: 0 51 42
2nd: 18 74 61
3rd: 23 98 80
4th: 28 118 97
5th: 31 134 110
Hope this helps.
Ted
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Last edit: 16 Apr 2009 21:10 by tk11b40. Reason: typo
- tk11b40
16 Apr 2009 21:02 - 16 Apr 2009 21:04
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Last edit: 16 Apr 2009 21:04 by tk11b40.
- PLUMMEN
16 Apr 2009 21:07
tk11b40 wrote:
thatsmy favorite personal gearing ive used with 530 chains on several big inch kaws.winds out around 125-130 with my 200 lb fat ass on there but you get there reallyfast! :laugh:16 tooth counter sprocket
Min Max At Power
Gear MPH MPH MPH
1st: 0 51 42
2nd: 18 74 61
3rd: 23 98 80
4th: 28 118 97
5th: 31 134 110
I ride a Ducati Monster on the track, 148 indicated on the speedo is about as fast as I have seen. Thats the speedo mind you I'm trying to look at it as I approach the "Dogleg" of the Reno Fernley raceway. Ahhhts a littel scary there, your lookin at that dogleg and praying you make it through.
I set mine up for 110 mph. I know it will get there, and I have no need to ride the street any faster. At redline the chart says it will hit 135, but I would be surprised if it got to that speed. It will be quick, and hit a pretty good top speed.
Hope this helps.
Ted
- tk11b40
16 Apr 2009 21:14
Hey thanks!!
Thats reassuring, it's exactly what I was "cypherin" for!!
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- PLUMMEN
16 Apr 2009 21:37
on my blue z1 between the unbraced frame and breathed on 1197 with that gearing it was a handfull to keep it straight and keep up with the tach when i felt the urge to educate certain kids on plastic bikes from stoplight to stoplight,youll be happy with that gearing! :laugh:
- Calhoun
18 Apr 2009 19:14 - 19 Apr 2009 04:56
Great info. gang!! It was a busy day today.mounted the rear master cylinder and finished the swing arm bolt spacers. Installed a steering stop and put the old cover (Kawasaki) over the front brake line splitter.
Remember brothers, "It's all about the ride."
Last edit: 19 Apr 2009 04:56 by Calhoun.
- Calhoun
19 Apr 2009 04:58
- Calhoun
22 Apr 2009 16:01
I called sprocket specialists today, A young female answered the phone and send that they do not make offset sprockets. :side:
:side:
I guess I will call back and talk to someone else.
- Calhoun
22 Apr 2009 16:21
Just ordered a 5/8" offset, 16 tooth, 630 sprocket from Pingle. $62 !!! Most folks want $80
- timebomb33
22 Apr 2009 16:49
try dg chassis , pmfr or there is a new outfit at least to me called rebel gears they actually build a lot of wierd ball stuff not that offset sprockets are weird, dg chassis built both of my offset 530 5/8th offset sprockets a 16 tooth and a17 tooth. they do very nice work. rebel gears will make anykind of rear sprocket that you could need all you will need is the year and model of back wheel and the sprocket size you want to go to and they will do it up for you.
I THINK MY POWERBAND BROKE
