Modified KZ1000 Hopefully a knee-dragger project.
- Calhoun
- Hayabusa= I ride to the strip club in flip flops
Re: Modified KZ1000 Hopefully a knee-dragger project.
27 Apr 2009 13:41
That is the old MKII fender that came on the bike. It only took me like 6 frigin hours. It is mounted now and looks amazing!
80 IT175, 84 XL200, XT250, 95 ST1100 96 xr650l (30k miles),kz1000, KX250 97'
Last and most important 93 KX500.
- mark1122
- Keep twisting it
27 Apr 2009 14:41
Does a mk11 have an 18" wheel? usualy the larger dim fenders look out of place on the 17" wheels.
the fit on your new 17" wheel is very good. It looks perfect in the pic.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Calhoun
27 Apr 2009 15:59
- Calhoun
27 Apr 2009 16:00
- Calhoun
27 Apr 2009 16:02
- mark1122
- Keep twisting it
27 Apr 2009 19:24
It looks great!
Fill us in, how is it modified? u must have changed the radius. it fits the 17" wheel perfectly. Was it originally made for a 19" wheel?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
27 Apr 2009 19:46
at last somebody got it right,looks good!
- Calhoun
27 Apr 2009 19:47
I think that I am in a jam. I am having a hard time figuring out what to do about the rear sprocket. I decided but now I am not so sure.
I am thinking about switching to a ZRX1200 wheel. The 1200 wheel cush drive will accept kz sprockets. Mark has told me this as well.
I have a ZRX1100 wheel and can not remember, or figure out what to do.
I would like to run the 630 chain but at this point I do not have to. I am still worried about running a small enough rear sprocket.The old one was a 30!
I do not want to have to buy a special sprocket when it is time for a replacement.
Will a 1200 cush drive fit the 1100 wheel? My zrx sprocket is a 45 and 42 is the smallest JT offers.
- Calhoun
27 Apr 2009 19:55 - 27 Apr 2009 20:16
Well you have to pull the sides out. This will make the side to side arch broader.It will also bring the tips toward each other.(I tried to upload a drawing but it did not work.)
you will have to make a bend in the mount flaps.
You will have to flaten or cut the rolled edge of the flaps to make a permanent bend. This will make the flaps stick down (again) instead of out at an angle.
next the rear needs to be broadened or the tire will hit on the outer edges.
now you just bend it to the best of your ability by hand.I turned mine over and pushed down on the tire.
Last edit: 27 Apr 2009 20:16 by Calhoun.
- Bad Kaw
- Flying Squirell
27 Apr 2009 21:52 - 27 Apr 2009 21:52
Save yourself the hastle and convert to a 530 or (for more clearence) a 520. All you have to do then is get a front sprocket; which you will need to have in the 'off-set' variety anyway to run a wide 17" on the rear.
-KR
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
Last edit: 27 Apr 2009 21:52 by Bad Kaw.
- timebomb33
27 Apr 2009 22:12
that looks so good with the stock type steel fender i was wondering how i was going to that myself with out wrecking it i have a 91 1100 kanoftuna front end on my bike and i hate the stock plastic crappy front fender so this solves my problem thanks very much for being my guinea pig, again nice job.
I THINK MY POWERBAND BROKE
- mark1122
- Keep twisting it
28 Apr 2009 05:10 - 28 Apr 2009 05:50
I have a zrx12 rear hub hear if u need any measurements just holler.
have u bought a front sprocket yet? i would try to make do with a 1/2" offset if u can. i went with a 5/8" so i could get more tire to chain clearance. but, in doing so i ended up with a non o ring chain for a thinner chain profile. I should have clearanced the frame more or went with a 1/2" offset.
It is a tight fit all around with the zxr arm. I often wonder, why guys that use other types of swingarms dont have as much trouble? i wonder if it has anything to do with the steering neck? i took great pains to line up the front and rear rims. in doing so it force the rear rim to the left, causing fit issues.in the end, i can see that the rear rim is offset to the left , when veiwed from behind. even though the rear rim is in line with the front rim.So maybe it is luck of the draw,depending on the steering stem alignment???
I found it very difficult to get all the clearance I wanted. I felt I needed the 5/8†to get it. The down side with a 5/8†is that if u are planning on launching it at the track, u should have a support plate(so I have heard). This helps prevent flexing and possible damage to the counter shaft. It seems u can get away with out the plate when only going with a ½†offset.
some guys actually cut the frame out and insert a channel for maximum clearance.and dont forget to clearance the footpegs, lower, inner bolt boss.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 28 Apr 2009 05:50 by mark1122.
