Modified KZ1000 Hopefully a knee-dragger project.
- mark1122
- Keep twisting it
Re: Modified KZ1000 Hopefully a knee-dragger project.
14 Apr 2009 17:36
I am running 630 16 35 with 17" rims. this will give u near stock ratios. if u look into the kz sprockets, u will find that 1 of them will fit the rear zrx rim.thats what i am using. i just dont know wich year my sprocket came from(77?). if u look at the JT sprocket cat, and find the zrx size (bolt spaceing and center hole size) u can match it to the kz sprocket.
1 tooth at the front = 2.5 at the rear.
If u have a kz sprocket now , just try it on your zxr rim, it may be good like mine was.Maybe all the kz's are the same?
www.jtsprockets.com/52.0.html?&L=0&sel_uid=4680&p=
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Calhoun
- Hayabusa= I ride to the strip club in flip flops
14 Apr 2009 19:54 - 14 Apr 2009 20:26
That is very useful information.
My 1980 had the enkei mags on it and The sprocket is small and has a hole 1/3 the size of the ZRX. FYI
zrx1100 sprocket
zrx1100 sprocket
80 IT175, 84 XL200, XT250, 95 ST1100 96 xr650l (30k miles),kz1000, KX250 97'
Last and most important 93 KX500.
Last edit: 14 Apr 2009 20:26 by Calhoun.
- Calhoun
14 Apr 2009 20:27
- timebomb33
14 Apr 2009 21:05
hey leon are you gonna have enough room for a 19 tooth front it might run a tad close. with a 630 chain a 16 tooth is about max if i'm not mistaken what the max is with a 520 i'd only be guessing.
I THINK MY POWERBAND BROKE
15 Apr 2009 12:17
i can't answer that question yet.i do have the 18 and 19 toothers setting on the bench two feet from my z1r.i did not have time to pull the cover and check(i was busy machining aluminum for roynor).my buddy that ordered them for me is a roadracer and he said they looked like rear sprockets :laugh: .
leon holmes
leon holmes
15 Apr 2009 12:52
- mark1122
- Keep twisting it
15 Apr 2009 13:08
I have a spare aluminum 37 tooth sprocket if that is of any use to u. it will fit, but i felt it was too many teeth for me.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- tk11b40
15 Apr 2009 20:49
Ah ha,
Now I understand the gearing question!!
Sprocket Specialties.
I'll get the tooth count and a couple photos in a day or two.
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- timebomb33
15 Apr 2009 20:58
i always like to give myself what i call kink room [don't get any ideas now omr and plummen] i try to have enough room between the front of the sprocket and chain combo and between the cases that if you get a bad kink in a link it wont take out your cases when it goes around the sprocket so i error to the roomy side of things i find it is easier to just get a smaller rear sprocket instead.
- tk11b40
15 Apr 2009 21:02
www.sprocketspecialists.com/
I goofed a bit, it's "sprocket specialists"
www.sprocketspecialists.com/SprocketOptimizer2.aspx
The second link is a gearing calculator, you may find it helpfulB)
Ok that should ive you somethin to chew on. I cyphered all this once before, to get just a little lower gearing than the old stock KZ set-up.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- Calhoun
16 Apr 2009 00:47 - 16 Apr 2009 00:53
Yeah! This is all very exciting. Thanks guys!I should be able to order sprockets and a chain in a week or two.
I'm sure we can figure out what is needed. I am am pleased with the gearing with the old wheel. I would like to go slightly higher if possible.
I got the gas for the welder today. Time to make a steering stop and mount the rear master cylinder.
Gnarley
Gnarley
Last edit: 16 Apr 2009 00:53 by Calhoun.
- mark1122
- Keep twisting it
16 Apr 2009 05:19
When u say, u would like to go slightly higher,on the gearing, do u mean u want more torque, or less?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
