OMR: '76 KZ900 Restoration/Modification
  • jtmcculloch
  • jtmcculloch's Avatar
Re: OMR: '76 KZ900 Restoration/Modification
03 May 2009 18:28
#287627
Interesting thread.
For comparsion lets look the ZXR1200R specs.
www.zrxoa.org/webpages/generalinfo/facto...cs/factoryspecs.html
1164cc
10:1 compression
4 valves per cyl.
Keihin CVK36 carbs
Kawasaki Throttle Responsive Ignition Control (K-TRIC)
Top Speed 141.1 mph
1/4 mile 11.135 sec. @ 119.775 mph
Horsepower 96.3 @ 8300 rpm
Torque 70.1 @ 5500 rpm
This is a modern high tech carbed engine. These figures are measured at the output shaft - not the rear wheels.
76 KZ1075
93 ZR1100
05 Honda ST1300
71 Moto-guzzi 750
  • timebomb33
  • timebomb33's Avatar
03 May 2009 18:37
#287632
why is a 1000cc air cooled 4 cylinder that is over a 100 horsepower so hard to believe when these guy's used to road race these things they 130 or 140 horse with a 1025cc limit and they made them last a complete road race screaming the gut's out them for an hour or more and that was 25-30 years ago technoligy is better parts are better built and more plentiful so why can't it be done.i just don't understand why this is so hard to believe. i've built them ridden them and raced them for 15 years+ now and it is possible and does happen every day the new motor i'm putting to together should make around 170 horse if i do every thing right and so far it is looking like it is.i have no problem believing that dave's motor once it is set -up and the carbs are jetted down and the motor has a few breakin miles put on it it will make very close to 100 horsepower at the rear wheel.
I THINK MY POWERBAND BROKE
  • arai59
  • arai59's Avatar
03 May 2009 19:05
#287643
At these levels your approaching ZX-14 power. You mean to tell me that a kz 1000 can match wits with a ZX-14 ? Oh boy.........this is gettin good. Do you run the infamous Terlingua Galatyn snake oyl ?
  • PLUMMEN
  • PLUMMEN's Avatar
03 May 2009 19:23
#287645
  • PLUMMEN
  • PLUMMEN's Avatar
03 May 2009 19:27
#287647
jtmcculloch wrote:
Interesting thread.
1164cc
10:1 compression
4 valves per cyl.
Keihin CVK36 carbs
Top Speed 141.1 mph
sure ive got no problem believing a well tuned blueprinted small bore old kaw can hang with a stock zrx,by all means ask solomrus about the old blue 78 1000 he had with really mild 1075 kit that used to whip up on his stock zrx ! :laugh:
  • arai59
  • arai59's Avatar
03 May 2009 19:30
#287649
PLUMMEN wrote:
Precisely. Hey Plummen.......pass the Hookah.
  • jtmcculloch
03 May 2009 19:38
#287662
KZ vs ZX-14 - Cant wait to see that race :)
76 KZ1075
93 ZR1100
05 Honda ST1300
71 Moto-guzzi 750
  • Old Man Rock
  • Old Man Rock's Avatar Topic Author
03 May 2009 19:44
#287672
Well well... You boys have been busy I see. :blink:
Well all I can tell you is what was reported to me after the Dyno test... 86HP and as mentioned, on non perfectly jetted carbs.
As for reaching another 7-10hp with some additional break in period for pistons, rings, cam timing components, camshafts, new valves, and carb tweaking etc... seems to me this should be doable.
And if I only reach 90HP tops at the rear wheel, shit, I'm cool with that as well. If it stays @ 86HP, I'm good with that as well...
As mentioned previously, was running rich (same as when Dyno was performed) so dropped a clip position from 4 to 3 to lean her out which effects 1/4 to 3/4 rpm range, I also went from a 120 main jet down to 115, adjusted the pilots for more lean operations and took her for a test drive...
All I can say is this... @ 65mph, you twist the throttle you better be holding on.... :woohoo:
As for listening to several of these guys, learning and using there experiences and expertise, they haven't let me down yet, so as far as I'm concerned, I should be close to these numbers for what I've done to this motor following their guidance.
Case & point, they said when finished and dialed in, probably end up around 93-95... With non tweaked carbies came in at 86hp... I don't know about the rest of you but how much closer to what was being said compared to Dyno results can you get.... ;)
As for being offended, naw, don't sweat it for I don't take offense easily, thicker skin then that...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • timebomb33
03 May 2009 19:48
#287675
by the way a zx-14 has at the back wheels not at the crank like you guy's are saying about 160+ horsepower and over a hundred actually around 110 ftlbs of tourque so you would have to have one hell of a motor to keep up to that.
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
03 May 2009 20:53 - 03 May 2009 21:02
#287702
I was gonna "move right along" to the next thread...but nah...what fun would that be. :lol:
Gonna hafta back-up Plummen and OMR. Their numbers are totally legit and reasonable. And I'll pull the Solumnruss card myself, the guy is a very nice guy, KNOWS his 220,000rpm induction fans, is a mechanical genius, and knows how to build a bike. I'd also throw my 40 years in on this, being born into a bike-shop (my dad's) and still stay connected to the industry (albeit loosely), although my main occupation isn't at a bike shop these days. Less than 5 years ago I worked at a shop where I got to play dyno-boy all day long. Dynos vary wildly in their numbers from dyno to dyno; your bike's power out-put is the same regardless of one dyno saying "100 bHp" and one saying "10 bHp". Biggest tool a dyno is = helps you get your bike dialed in correctly; always use the same dyno and you'll know if your mods are working. Bounce from dyno to dyno to 1.) compare dynos, or 2.) confuse youself into thinking that your PCIII (I'm sorry, your jet-kit!;) ) actually got you 15 bHp because you before/after tested it on different dynos. Be wise.
Having said all this, use a dyno for what it's for = excellent tuning tool.
When I was working at a motorcycle speedshop in LA in the late 90s, the lead mechanic at the shop was Chuck Grave's top mechanic and spun wrenches for some front row AMA Superbike and Supersport racers. The guy trained under Kaz Yoshima and knew his stuff; and I suspect that Pauly probably surfs this site from time to time as he's an old-school superbike kind of guy...I'd know, I gave him a ELR clone for some un-obtainium work he did for me back in the day. He worked on the old school KZs and they used an eddy/current (sp?) dyno back then and these numbers are very achievable. ZX14s put down 180 at the rear wheel...I don't recall anyone posting here that they're going to get over 180 with a 1015 kit, a bank of 29s, and some head work. :dry:
My tired old 'J' puts 89 at the rear wheel with an old 'Trapp and a set of 36mm Mikuni flat-slides (yes, it's way too much carb...I'm just sayin') with K&Ns, a ZX6R rear wheel, and 530 chain/sprocket (think I missed out on 'reciprocating mass' day in physics?:laugh: ). Stock motor. That's about right, I'd say...maybe even a little weak. I dunno, it's just an 81 KZ1000J, but that seems pretty 'right' to me. :huh:
Moving right along...:woohoo:
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
Last edit: 03 May 2009 21:02 by Bad Kaw.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
04 May 2009 07:06 - 04 May 2009 07:14
#287767
Old Man Rock wrote:
Sure enough, he replied 86HP and I was running really rich. Asked what jets, 120's, he said drop down to 108-110's on the main jet, adjust the pilots and re-synch I'd be good to go....
Dumb question.
Why is it nesseary to re-synch after a pilot or main jet adjustment? The slides are still in the same position.:S
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 04 May 2009 07:14 by mark1122.
  • PLUMMEN
  • PLUMMEN's Avatar
04 May 2009 07:55
#287777
fine tuning B)
