Dutchz Z1 road burner - new stuff
  • dutchz
  • dutchz's Avatar Topic Author
Re: Dutchz Z1 road burner - new stuff
05 Jul 2011 16:51
#461175
Thanks Ruff. The headlight is a small H4 with hi/lo beam, you can find it here:http://www.airtech-streamlining.com/miscpages/lights.htm
The numberplate with headlight recess was a one-off but if there's interest I can have a mold made
1974 Kawasaki Z1
Stock front hub and rear axle.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
05 Jul 2011 19:07
#461185
that lighter bat should make u faster at the track.
Good luck, and keep 2 wheels down. :P
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • DoctoRot
  • DoctoRot's Avatar
18 Jul 2011 21:58 - 18 Jul 2011 21:58
#463593
WOW. I just stumbled upon this thread and went through it. Beautiful bike and craftsmanship. You have inspired me to keep my stock swing arm and brace it up instead of swapping for a newer one. I'm thinking about putting an under-brace on it. If you don't mind me asking, did you make a jig for the swingarm when doing the modifications? Got any pics?
Last edit: 18 Jul 2011 21:58 by DoctoRot.
  • dutchz
20 Jul 2011 19:21
#464010
DoctoRot wrote: WOW. I just stumbled upon this thread and went through it. Beautiful bike and craftsmanship. You have inspired me to keep my stock swing arm and brace it up instead of swapping for a newer one. I'm thinking about putting an under-brace on it. If you don't mind me asking, did you make a jig for the swingarm when doing the modifications? Got any pics?
Thanks man. No I didn't make a jig, free handed the bends, tacked the brace on the arm then checked it on the bike for chain clearance before final welding. All my pics are in this thread.
I think Leon (blackbanshee531) did a very nice under braced arm for another member and posted some good pics on this forum. I don't know if he jigged it. Rob (rstnick) has a nice under brace on his KZ650.
Attachment swingarm.JPG not found
Attachment swingarm1.JPG not found
Attachment swingarm2.JPG not found
1974 Kawasaki Z1
  • tobiism
  • tobiism's Avatar
20 Jul 2011 22:24
#464037
Did you find that the braced swingarm made any noticable difference in handling?
  • dutchz
20 Jul 2011 22:32
#464040
It handles much better than stock, but it's impossible to say how much of that I can attribute to the swingarm bracing. I also extensively braced the frame including the headstock, used heavy duty motor mounts, light weight wheels, raised the rear 2", and got the weight down to 430 lbs with a full tank. package deal ;)
1974 Kawasaki Z1
  • Nitro Mick
  • Nitro Mick's Avatar
  • 1984 GPz1100 & 1976 Z900
25 Sep 2011 10:57
#479400
Just went through all 23 pages.
Heaps of ideas for my 76 Z9.
Thank you for sharing.
I used to be playswithnitro but; it happens...
  • notaduc
  • notaduc's Avatar
29 Apr 2012 19:51 - 29 Apr 2012 19:52
#518684
dutchz wrote: Thanks Mark, it's coming along. If I get these brackets done there's just brake lines and some finish work left... Now if my knee would bend another 20 degrees.
Let's try this video thing:
Any chance this video still exists somewhere??
I really want to hear this thing
1980 (mostly) KZ1000
Last edit: 29 Apr 2012 19:52 by notaduc.
  • wolfey
  • wolfey's Avatar
Re: Kawasaki Z1 road burner done… build pics
05 Nov 2013 04:32
#612130
dutchz wrote: Put some knurling on the shift linkage. Also got some solid pegs with rubber sleeve to replace the knurled flip-up ones.
i know this is a old post but ive been looking for a linkage adapter like the one in this pic dutchz were did u find it i wish to do away wth my stock shifter and go to linkage shift
building something is better then just buying someone elses blood sweat and tears
  • DoctoRot
  • DoctoRot's Avatar
05 Nov 2013 13:57
#612176
wolfey wrote: i know this is a old post but ive been looking for a linkage adapter like the one in this pic dutchz were did u find it i wish to do away wth my stock shifter and go to linkage shift
fastfromthepast.com sells tarozzi rear sets and a bunch of rear set parts. check it out.
www.fastfromthepast.com/servlet/the-Rearset-Parts/Categories
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
07 Nov 2013 14:33
#612344
This place also carries an assortment of linkages etc:
www.midwestcontrol.com/
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
07 Nov 2013 15:03
#612349
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
If you're feeling crafty you could pick up a used shifter assembly from a KZ1000 police bike as s starting place. For example:
Specifically, the piece that goes on the shifter shaft is part number 13156-4001, and it's still available from Kawasaki. It looks like this same part was used from '78 to '05, so it should fit on the older bikes.
My dad's '74 Z1
'00 ZRX1100
