Dutchz Z1 road burner - new stuff
  • dutchz
  • dutchz's Avatar Topic Author
Re: Dutchz Z1 road burner - quick turn throttle
22 Jan 2011 17:48
#424477
Of course the tube does not fit the housing - that would be to easy :laugh:
The spool hits both halves of the clam shell housing. A wee bit where the cables come in and a *lot* on the side where the cables hook to the spool. The 36mm diameter is measured along the round part of the spool not where the cables hook in, by the way.
I started by removing the casting marks inside the housing:
1974 Kawasaki Z1
Stock front hub and rear axle.
  • dutchz
22 Jan 2011 17:49
#424478
...and spent another hour or so with the dremel to open the housing up:
1974 Kawasaki Z1
  • dutchz
22 Jan 2011 17:51
#424479
Sanded the Z1000 spool down some:
1974 Kawasaki Z1
  • dutchz
22 Jan 2011 17:55 - 22 Jan 2011 17:55
#424481
Kept going until there was absolutely no binding whatsoever - for obvious reasons. The end result below. Bottom mark on the tape was original WOT mark. Top mark is the current one. Big difference, total cost for this improvement: $10. Throttle snaps shut hard just like it did before.
1974 Kawasaki Z1
Last edit: 22 Jan 2011 17:55 by dutchz.
  • dutchz
22 Jan 2011 18:02
#424487
Just FYI I did hold up the Z1000 tube to the stock Z1 switch housing, it will not fit in there - it may if you do the modifications I did to the MP housing - have not tried as I am not using the stock switch.
I also read somewhere an SV650 throttle tube is 33mm - have not verified. That tube would give you a bit quicker action, should logically put you half way between the two marks and would be much easier to fit in either housing...
1974 Kawasaki Z1
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
22 Jan 2011 19:08
#424508
dutchz wrote:
Picked up a Z1000 tube from Motion Pro (thanks Corey!).
You're welcome Dutch!
Buttonwillow Raceway March 19-20 for the AFM Races. Be there!!!
'85 GPz550(ZX550-A2)
  • dutchz
22 Jan 2011 23:28
#424594
I will try my damnest!
1974 Kawasaki Z1
  • porchev914
  • porchev914's Avatar
23 Jan 2011 00:41
#424597
Cool Dutch, thanks for the info. I also hated having to reposition my hand to firewall it :)
FRANKEN Z!
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Dutchz Z1 road burner - new stuff
24 Jan 2011 08:36
#424941
sweet mod dutchz!
thanks for documenting it,
  • dutchz
24 Jan 2011 14:19
#425044
You're welcome guys. Went riding yesterday and love the way it feels. I wasn't sure how quick I was going to get used to it but it really didn't take long at all. You have to be smoother at small throttle openings but the throttle feeling is a huge improvement, feels a lot more direct. Well worth $10 :laugh:
1974 Kawasaki Z1
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
24 Jan 2011 16:42
#425093
Great little mod Dutch. Thanks.
Excuse me if i missed the answer to this before, but,
How do u like your new header? does it have more bottom end with the 2" collector?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • dutchz
24 Jan 2011 23:17
#425221
Hey Mark, thanks. Yes it seems to have better midrange performance than the Yosh did - as far as I remember, not exactly a back to back test. Unfortunately I have not had the chance to throw the bike back on the dyno, hopefully later this year.
1974 Kawasaki Z1
