Dutchz Z1 road burner - new stuff
- dutchz
Re: Dutchz Z1 road burner - new stuff
31 May 2010 11:00
I made a saddle for the exhaust hanger. IMO you should not weld and exhaust hanger tab straight to the tailpipe, vibration will make it crack and fail. The saddle disperses the pressure and makes for a much stronger mounting point.
1974 Kawasaki Z1
Stock front hub and rear axle.
- Old Man Rock
31 May 2010 11:07
Dutch... On your bending, sand and Bend or mandrel?
Just luv it keep em coming...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- loudhvx
31 May 2010 11:16 - 31 May 2010 11:17
dutchz wrote:
Couldn't agree more. Seen a few crack right off and leave a hole.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 31 May 2010 11:17 by loudhvx.
- loudhvx
31 May 2010 11:19
dutchz wrote:
I don't think I've seen that before. Are all 4-into-1's like that, or only the good ones?
1981 KZ550 D1 gpz.
Other links.
Other links.
- Jack
31 May 2010 11:27I don't think I've seen that before. Are all 4-into-1's like that, or only the good ones?[/quote]
A little useless trivia- the bullets are also known as goillets.First ones I saw were on pipes built by Byron Hines or Dennis Murray, before disco.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- porchev914
31 May 2010 13:35
FRANKEN Z!
- Old Man Rock
31 May 2010 13:44
For exhaust components....
As you'll soon come to realize, this crap ain't cheap...:ohmy:
www.coneeng.com/exhaust_system_kits.html
www.spdexhaust.com/CollectorsB.html
www.burnsstainless.com/4into1.aspx
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- dutchz
31 May 2010 14:25
OMR - the primaries are off a Wolf pipe I bought on ebay. they have nice soft bends and may well be hand bent. I bought my collector, transitions and a U bend from Cone. I just got the mild steel stuff since the whole pipe will be painted or coated anyway.
The bullets are supposed to increase flow. They also take up the star shaped gap in the center of the four primaries so you don't have to blow weld or plate that shut - you can see that real well on porchev's pic, my Yosh is the same way.
1974 Kawasaki Z1
- dutchz
31 May 2010 14:31
Trimmed up the tailpipe some more and tacked the transition cone to it.
These are the component sizes:
- primariess 1.5"
- collector 2"
- transition 2" to 2.5"
- bend 2.5"
- transition 2.5" to 3"
- megaphone 3" to 4" + race baffle
- primariess 1.5"
- collector 2"
- bend 2.5"
1974 Kawasaki Z1
- dutchz
31 May 2010 14:32
1974 Kawasaki Z1
- dutchz
31 May 2010 14:33
1974 Kawasaki Z1
- dutchz
31 May 2010 14:49
Marked the bend with some masking tape to get the rough angles. Then just grind away little by little on the big grinding wheel (to keep the ends square) until it slips in place.
1974 Kawasaki Z1
