Dutchz Z1 road burner - new stuff
- iandz500
Re: Kawasaki Z1 road burner done… build pics
30 Jan 2008 15:39
nice work dutchz, cracking looking bike!
Bikes: 1960 lambretta Li125 sold; 2001 Honda CG125 sold; 2006 Yamaha FZ6 sold; 1980 Kawasaki Z500 sold; 1967 BSA Bantam D10; 2008 Aprilia Shiver sold; 2010 KTM Duke 690R; 1954 BSA Bantam; 1980ish Kawasaki Z200
- hannah1
17 Feb 2008 22:30
Dutch ,
I just bought a used pair of the same shocks that you are using . Do you know what the spring rate on yours are ? Mine came from a flat track bike that probably weighs 200lbs than the GPz550 they are going on , so chances are that the springs will be too soft .
Your bike looks awesome
Thanks , Mike
Thanks , Mike
- jimmybon
18 Feb 2008 01:05
Looking good Dutchz,
maybe drill and tap and fit button head allan screws to the bottom tree for adjustable steering stops
cheers
cheers
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
- jimmybon
18 Feb 2008 01:34
woops, didnt realize there were more pagers.sorry
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
- dutchz
18 Feb 2008 11:12
hannah1 wrote:
Hey Mike,
I had to swap springs on mine too, the came off a Harley bagger so they were sprung too soft. The valving (damping)seems to be right on the money though, luckily.
I ended up getting 8.3/120 springs. That's taking into account 420lbs dry weight, 200lbs rider in full gear, and intended use. It's fairly stiff for uh... spirited riding. Any stiffer would have made it a pure track tool, and it's not. I'd recommend calling Works and talking to one of the techs (ask for Sandy, real nice and knowledgeable guy). Measure the spring thickness with calipers so he can determine the original spring rate and take it from there...
Good luck!
Dutch ,
Thanks , Mike
Hey Mike,
Good luck!
1974 Kawasaki Z1
Stock front hub and rear axle.
- dutchz
18 Feb 2008 11:29
jimmybon wrote:
You found the other pics already... Looks like a nice, clean solution too!
1974 Kawasaki Z1
- hannah1
- dutchz
Re: Kawasaki Z1 road burner - new stuff (again)
24 Apr 2010 13:00 - 24 Apr 2010 14:17
The bike went untouched for about a year. I did a full motor rebuild, 1015 kit, Larry Cavanaugh head, cams, carbs last winter. I still had a few things I wanted to change/upgrade to get it where I want it: front end, front brakes, exhaust and some sort of half fairing. Trying to keep that 70s club racer look, so no Nissin four pots or upside down forks on this build.
This is how it looked before I tore into it (again):
1974 Kawasaki Z1
Last edit: 24 Apr 2010 14:17 by dutchz.
- dutchz
24 Apr 2010 13:02
I found an early police front end with beefier forks and clamps - 38mm and double pinch bolts. It's about an inch wider than the standard Z spacing which is good, because I am trying to cram some big dual piston calipers in there while still retaining the spoke wheels.
1974 Kawasaki Z1
- dutchz
24 Apr 2010 13:03 - 24 Apr 2010 13:09
1974 Kawasaki Z1
Last edit: 24 Apr 2010 13:09 by dutchz.
- dutchz
24 Apr 2010 13:04
1974 Kawasaki Z1
- dutchz
24 Apr 2010 13:08
Machined and additional groove at the top so I can put J-model dust boots on the forks. Don't like the look of fork gaiters that came on the police bikes (for this bike anyway).
1974 Kawasaki Z1
