Dutchz Z1 road burner - new stuff
- PLUMMEN
Re: Kawasaki Z1 road burner done… build pics
18 Jan 2008 04:58
- cafekz750
18 Jan 2008 07:40
I love the bike so far. I am checking in daily to see the new pictures of the bike as you have worked on it. What really stands out to me is the swing arm; it is fantastic. The wheels are spinning in my head...
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
- dutchz
18 Jan 2008 09:42
1974 Kawasaki Z1
Stock front hub and rear axle.
- dutchz
18 Jan 2008 10:30
October/november '07 - Complete rewire. This is as minimalistic as it gets with running lights. No starter. No turn signals. No keyed ignition. Couple of little tricks for functionality though... The oil pressure switch is connected to the brake warning light on my tach. If the pump goes out I'll know. Also, since I have no switch pod on the left side, I'm wiring my starter button as a hi-beam switch (made sure I checked with Lou - thanks man).
I ordered a bullet connector set and crimping tool from www.vintageconnections.com . Great stuff, same day shipping.
Post edited by: dutchz, at: 2008/01/18 16:41
1974 Kawasaki Z1
- dutchz
18 Jan 2008 10:32
The battery box is nothing fancy, just a piece of 3" square tubing stuck on the mill. It'll do the job. We welded on some hooks and I found a rubber strap at the salvage yard.
1974 Kawasaki Z1
- dutchz
18 Jan 2008 10:33
1974 Kawasaki Z1
- dutchz
18 Jan 2008 10:44
Here's the right switch housing. The starter button trick worked nicely, now I can flash my brights. The Grimeca master cylinder is another ebay find. It's big (19mm - 3/4"). I did my homework though (master cylinder/piston ratio) and I think it'll be alright with the brake splitter / switch. I won't know until I bleed the brakes and ride it...
1974 Kawasaki Z1
- dutchz
18 Jan 2008 10:48
I dropped the tach down some more so it doesn't stick out on the top. Made some real spacers this time on the lathe, instead of the brass coupling nuts from the plumbing department that I used before.
You can see the black brake lines I'm using. Modern performance in a period guise. I'm using Goodridge braided lines and fittings with the black vinyl coating.
Post edited by: dutchz, at: 2008/01/18 13:53
1974 Kawasaki Z1
- dutchz
18 Jan 2008 10:56
1974 Kawasaki Z1
- dutchz
18 Jan 2008 10:57
Put some knurling on the shift linkage. Also got some solid pegs with rubber sleeve to replace the knurled flip-up ones.
1974 Kawasaki Z1
- dutchz
18 Jan 2008 11:05
Cut the holes for the taillights. Don't like how far they're sticking out, so it will need some spacers and some bondo.
1974 Kawasaki Z1
- PLUMMEN
18 Jan 2008 11:05
cool!
