Building a GPZ1150 from a CSR1000
- otakar
Re: Building a GPZ1100 from a CSR1000
22 Jun 2009 06:27
Today I plan on Molly coting the skirts and Ceramic plating the crowns on the pistons. This means that I can pull off the top end tomorrow.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- mark1122
- Keep twisting it
22 Jun 2009 06:59
It sounds like your still having fun anyways.
Good luck.
Good luck.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- otakar
26 Jun 2009 10:14
I finally did some cam fitting. Since I no longer have access to a CNC machine I had to do it the old fashion way, with a dye grinder. I hate to do work in such a sloppy way, but I guess it will be functional and no one will know except me. I am really shocked how much space there is (or rather is not) for clearances with these new high lift cams.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
26 Jun 2009 10:15 - 26 Jun 2009 10:21
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 26 Jun 2009 10:21 by otakar.
- otakar
26 Jun 2009 11:40
Well- I discovered a problem. Somehow my new cylinders, that I just got bored by Pitstop performance, I bent the lower skirt of one of the outside cylinders. I attempted to straighten it out, knowing very well that it will most likely not work. After I succeeded making the lower lip round again, I checked it very carefully to look for what I already knew I was going to find, a crack about 3/16 of an inch long. Well, I was not going to install a new sleeve and have it re-bored, nor was I going to leave it there to continue creeping up the sleeve. Here is my solution.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
26 Jun 2009 11:42
I figured that if Kawasaki can manufacture a sleeve that looks like this, than mine is 1000x better and safer. If you will notice the red line on the sleeve in the picture, it is a crack. No wonder with sharp corners.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- mark1122
- Keep twisting it
27 Jun 2009 06:37 - 27 Jun 2009 06:38
Well done Otto. Well Done!
I'm sure u will be fine. No problem. Sometimes sleeves need to be clearanced like that for strokers, so they clear the crank.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 27 Jun 2009 06:38 by mark1122.
- otakar
27 Jun 2009 07:17
That is exactly what those square notches are on the 1300 sleeve. The 1300 is a long stroke engine where the stroke is longer than the bore.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
27 Jun 2009 08:54
Last night, I went to my brothers house to help him with his Zephyr 750 he put the engine back together and wanted me to check everything out before we fired it up. We did start and ran the engine for a while on an auxiliary tank. I never realized how cold blooded the Keihin carbs made it. It runs like crap until it heats up. Those carbs are real junk. Unfortunately because of the space restrictions due to the frame, Mikunis are out of the question.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- mark1122
- Keep twisting it
27 Jun 2009 12:14
otakar wrote:
What carbs are they??
that Would normaly mean they are jetted tooo lean on the pilots?It runs like crap until it heats up. Those carbs are real junk. .
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
27 Jun 2009 12:36
- kzr750r1
27 Jun 2009 14:11
otakar wrote:
If this is a crack how will the notches help?
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
