Building a GPZ1150 from a CSR1000
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: Building a GPZ1100 from a CSR1000
13 May 2009 06:53
#290766
Very Cool.B) I have never seen 10.5's for a gpz before.
are they usualy this shape, or are these dif?
It will be interesting to here weather they will accept pump gas with the high domes.
i hear u on the SUB's.what a pain it is to reshim.i have enough trouble doing them on the bench.:(
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • otakar
  • otakar's Avatar Topic Author
13 May 2009 07:56
#290777
I am not sure about the domes, Supposedly these are custom, I have no idea. These were made to fit the"Bathtub" while still using the earlier crank and leaves. Now I have to take the pistons and Ceramic coat the crowns and Molly coat the skirts.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • trianglelaguna
  • trianglelaguna's Avatar
13 May 2009 08:04
#290779
once again ...i love this thread....and yes ...the bike is looking great.....cool chin spoiler...i had one on my gpz...dont see em much nowadays.....nice pics...thanks...craig
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • otakar
13 May 2009 09:02
#290791
If you have any history on that spoiler, tell me. Year, Bike, Oryginal Kawasaki, ETC. ETC.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
13 May 2009 12:48
#290839
are your mtc pistons cast or forged?
good luck with the engine build.
leon holmes
  • trianglelaguna
13 May 2009 13:17
#290843
i think it was from a kit that folks sold during the gpz's short rule.......ive seen the kits and the closest one to the shape i had are white plastic molds and need to be drilled and painted.....mine mounted with angled inner bracketts to the engine mounts upper and under......was already installed and painted gpz red......ive seen some others but they were bulby looking or even way weird in finished product.....you can tell the good ones cause they fit and really hug the belly and header area.....the bad ones hang down too far....in a short first glance look at yours ity is a good product along the lines of how mine was and mine fit the 81gpz1100 like a glove....my 2 centsotakar wrote:
1976 KZ900
2003 ZX12R
2007 FZ1000
  • otakar
13 May 2009 17:27
#290900
Mine is molded out of BLACK plastic and was painted in original factory lacquer with the blue and silver stripes on it that were also factory. I know that they are still available today but made out of Fiber Glass and come white. These pistons are a forging.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • 531blackbanshee
  • Vendor
  • Vendor
14 May 2009 09:00
#291093
thanks for the reply otto.
leon holmes
  • otakar
21 May 2009 17:34
#293159
Well today I started putting together my New ported & polished head. I had some custom "shim on top" Titanium valve spring retainers made and I installed oversize stainless steel intake valves. This is the 84 GPz1100 head if you remember. the only thing that is left to do on this head is to paint it. I will be using Polane-B in a Titanium color for the entire top end. Here is a pic of the custom valve spring retainers.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
21 May 2009 17:36
#293160
Here is what the chamber looks like with the Mambo intake valves. I also installed new APE springs.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
29 May 2009 17:27
#294899
Well- today I did a bit of maintenance. I removed the chain and cleaned it. It had a few tight links, and I did not want it to destroy itself, along with the rear sprocket. I also finally put my modification into the Mikuni BS34 carburetors. I must say even though I have still to mount the 1140 top end on it with all of its goodies, the carbs make it run like a "Raped Ape" Where before things were getting a little stagnant between 5K and 7K revs, now it is where all of the action is. Now when it hits 7K it pulls like a monster. Those custom carb needles really seem to do the trick. Now I am getting really exited about putting the big top end on it. This thing will be a real monster. Now I only need a couple of small things for my fuel injection, and things will be almost finished.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • kzr750r1
  • kzr750r1's Avatar
30 May 2009 06:43
#294999
I found back in the thread a mention of your carb mod....
Can you expand a little bit on this???
Raped ape good. :)
Nice bit's your assembling here...
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
