Building a GPZ1150 from a CSR1000
- mark1122
- Keep twisting it
Re: Building a GPZ1100 from a CSR1000
09 Feb 2009 06:53
Sorry I don’t understand what u mean by restrictive?
Do u have a modern FI or the old gpz stuff?
The large throat of a 36mm carb is way to big to get good vacuum at low rpms , as you already said CV's just don’t, and can’t have good throttle response.
The hole point of FI is to improve atomization AND inject. so u don’t need good vacuum at low rpm to get to good response. with the CV's u waste a lot of fuel do to poor atomization. the old FI units did not have very good heads available at that time so they did a poor job, but the theory was correct. Now the nozzles have way more jets so the atomization is top notch at all rpms.
I wish I had the funds and more knowledge on this. I would love to try this out myself.:woohoo: I think it would rip.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mark1122
- Keep twisting it
09 Feb 2009 07:02 - 09 Feb 2009 08:15
otakar wrote:
The more i learn about flame travel the more i question the use of this chamber shape on a KZ. what do u think about this chamber as apposed to the standard shape?
It looks to me like they just did this to accommodate the larger 38mm valves . The deeper chamber can only cause the burn to take longer,thus depriving top end and promoting detination.
We can put larger 37.5mm valves in a kz head and have a smaller chamber to promote a better burn, or 38mm valves in the j head , but the j has a larger chamber than th kz. what is your take on this?
What are u going to set your squish clearance at ?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 09 Feb 2009 08:15 by mark1122.
- Tony
Author
11 Feb 2009 09:06
Hi otakar, I think I've read through your project build at least twice since you started this thread. Great job! Very inspirational.
I'm going to try and locate a source for polane today. Thanks for all the advice.
- otakar
11 Feb 2009 10:23 - 11 Feb 2009 10:23
Hay Tony, I left the ifo about Polane in the oryginal "Gunkote" thread for you.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 11 Feb 2009 10:23 by otakar.
- otakar
28 Mar 2009 16:04 - 28 Mar 2009 17:05
Well-- I finally got to installing my new headlight and HID Xenon system. It is a drurry day outside so I figured it was a good day to do it. All I can say is WOW :woohoo:
Here is a picture of the placement of Ballast.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 28 Mar 2009 17:05 by otakar.
- otakar
28 Mar 2009 16:07
Here is another view. The ballast is installed with the heavy duty interlocking Velcro like is used on Toll transmitters on your windshield.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
28 Mar 2009 16:11
Here is the new headlight compared to the old. The new one has the mounting ring already mounted. It has a clear lens and the light dispersion faceting is on the reflector. The light is a modified car headlight.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
28 Mar 2009 16:12
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
28 Mar 2009 16:14
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
28 Mar 2009 16:17
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
28 Mar 2009 16:18
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
28 Mar 2009 16:20
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
