My '76 z900 'Strip-fighter...sorta
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: My '76 z900 'Strip-fighter...sorta
27 Feb 2009 09:41
#268455
the r1 rear caliper uses the same type of mount.i like it because it eliminates the brake stay rod.
  • StreetfighterKz
  • StreetfighterKz's Avatar Topic Author
27 Feb 2009 11:45 - 27 Feb 2009 11:47
#268480
Some of the underslung, torque armless caliper brackets slide in groves that are welded to the inside of the arm. But my extension are going to have a 5" adjustment range so I won't be able to use a stock hanger as I'll run out of travel available for the hanger. There is a guy selling a CNC bracket on eBay which is where I got the idea from. I was thinking of making my own copy but for $45 for the billet one on eBay, I might just buy that one as it'll be cheaper and easier than trying to make my own. His is specifically made for extended arms and uses the axle slot to keep the hanger from rotating, so that axle travel won't cause a problem.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 27 Feb 2009 11:47 by StreetfighterKz.
  • 531blackbanshee
  • Vendor
  • Vendor
27 Feb 2009 13:31
#268504
that looks like a very nice piece.seems a bargain for $45.00
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
28 Feb 2009 04:33
#268615
Thats a fine looking peice there , Doug. Very trick looking, and at $45, thats a steel.B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • StreetfighterKz
03 Mar 2009 19:17
#269508
I was able to get to the machine shop at the power plant and get some machining done on the triple clamps.
I cut off the ignition switch mounts and had them machined as close as I felt comfortable with. I also had the steering stabilizer lug milled down as I won't be using it.
I still need to take some files and sand paper and finish up removing the rest of the unneccessary material but at least its some progress.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • timebomb33
  • timebomb33's Avatar
03 Mar 2009 19:47 - 03 Mar 2009 19:49
#269514
at least your doing constructive things at the power plant unlike homer simpson[plummen] not eating doughnuts.by the way what is the red button for!
I THINK MY POWERBAND BROKE
Last edit: 03 Mar 2009 19:49 by timebomb33.
  • PLUMMEN
  • PLUMMEN's Avatar
04 Mar 2009 03:54
#269546
:laugh:
  • StreetfighterKz
30 May 2009 16:04
#295109
Finally accomplished something big enough to post about it.
Waaayyy back on page 4 and six months ago I had posted pics of the chain adjusters cut off of the Gsxr swingarm in preparation for swingarm extensions. I finally squared the ends and then notched the ends so when I get my extensions machined the arm will be ready for them.
Ends squared and cleaned up...
Notch laid out...
Rough cut...
Filed to perfection...
Both sides ready for the extensions...
Up next is the mounting of my 13 row Earl's oil cooler. I've had the cooler for a good while but I had to wait until I got an exhaust so I could figure out where vertically the cooler had to be mounted.
The cooler didn't come with any mounting hardware....go figure. I went to Lowe's and picked up a 3' length of 1.5"x1.5"x.125" aluminum angle and cut it to size, drilled and filed holes for the cooler inlet/outlet's to pass through and four holes to run long bolts to sandwich a similar bracket for under the cooler.
For a clean look I'm going to run the lines up under the tank and as you can see from the picks the -8AN 90deg fittings fit like a glove.
I haven't finished a bottom support yet but it will be run from the horizontal brace between the front engine mounts to the middle of the bottom bracket.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • PLUMMEN
  • PLUMMEN's Avatar
30 May 2009 16:27
#295119
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
31 May 2009 07:38
#295274
Great work there Doug.B)
u may want to mount the fork tubes and check for clearamce. It looks ok in the pic, but i know it was an issue for me. I have the same cooler. if i mounted it too high, the forks hit the cooler.
Just a heads up bud.B)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • StreetfighterKz
31 May 2009 09:16
#295285
I had the the forks mounted when I figured out where to put the cooler, but I took them back off so I could get everything assembled and tack welded. The fork tubes will hit the tank before they catch the -8AN fittings. Thanks for the suggestion though!
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • StreetfighterKz
26 Oct 2009 17:15 - 26 Oct 2009 17:16
#329794
Progress!!!! Well at least a little progress.
I left off 5 months ago with needing a lower oil cooler bracket and stay fabbed up. I finished it finally. I welded a tab to the cross brace between the two front down tubes. After getting the lower cooler bracket remade so that the everything was where it needed to be I made a simple yet effective stay.
I also finally got a offset sprocket for the front. It's a 19T which seems large but it clears everything. The nice thing about the bigger sprocket is that the chain shouldn't lay on the swingarm as much.
I did run into a problem and I don't think it would have mattered what size sprocket I planned on running. The crossmember for the upper shock mount is too low and the chain can't make a straight run to the rear sprocket when the suspension is even slightly compressed.
It kind of hurt to do it but I had to break the tack welds for the crossmember and notch it using a piece of left over crossmember tubing.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 26 Oct 2009 17:16 by StreetfighterKz.
