My '76 z900 'Strip-fighter...sorta
- StreetfighterKz
14 Jan 2007 13:00
Here are a couple pics of my pro-street bike. Not a whole lot to show as everything is in various states of completion.
The "current" chassis parts list is as follows:
'01 Gsxr600 Forks lowered 3"
'01 Gsxr600 Brake caliper (maybe later on some 1000 six pots )
'95 Gsxr750 Front rim
Tag Handlebar risers
Ducati M750 handlebars
CBR900RR Remote Reservoir Brake M/C
ZX12 starter switch assembly
Magura Push/Pull Throttle Assembly
"Secret" Clutch Lever Assembly
Tarozzi rearsets
'91 Gsxr750 swingarm (will be extended 4-6" (no not with wood either))
'92 Gsxr1100 shock linkage w/custom length dogbones
'95 Gsxr750 rear rim
'9? Zx7 rear brake caliper & M/C
'02 Gsxr1000 front fender
Stock KZ tank with '96 Suzuki GSXR Filler cap
Corbin Gunfighter seat (stealing if from my 1000)
Maier side covers (with Dzus fasteners)
Stock tail (will be extended 4-6" using another tail section)
Current engine parts list:
-MTC 1428cc 13.5:1 pistons w/ buttons
-Z1 crank blueprinted, trued, and welded by Falicon
-Z1 head with bronze valve guides, 1.5mm OS S/S intake valves, stock size S/S exhaust valves, port work performed by Dean Frantz, outer 2 cylinders dual plugged (by FBG) for compression relief valves
-Web #109 cams
-MTC bigblock rebuilt and prepped by FBG
-FBG undercut transmission
-HD case studs, head studs, and main cap plate
-Windage tray
-Oilpan gate
Umm...I think thats it for now...
Later, Doug
Tarozzi rearsets
-Web #109 cams
-Windage tray
-Oilpan gate
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- StreetfighterKz
Re: My '76 z900 'Strip-fighter...sorta
14 Jan 2007 13:02
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- StreetfighterKz
14 Jan 2007 13:03
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- pumps
14 Jan 2007 14:40
Oh you have a LOT of work ahead of you!
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
1977 Yamaha XS650
2000 Kaw W650
- wireman
14 Jan 2007 16:59Please Log in or Create an account to join the conversation.
- StreetfighterKz
16 Jan 2007 14:16
Thanks for the compliments!
Wireman, all together I should have $3500-4000 in the motor when I'm done and about the same in the rest of the bike. If I can beat one Busa it'll be worth it.!:evil:
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- mark1122
- Keep twisting it
07 Feb 2007 19:00
Cant wait to see it.Its going to be fast.May as well add a turbo.:woohoo: :evil:
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Bad Kaw
- Flying Squirell
23 Nov 2007 11:05
StreetfighterKz wrote:
THAT's what I wanna hear!
Later, Doug
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- smclem
- www.osrbikes.com
24 Nov 2007 05:35
Doug-- looks like a lot of fun putting that together-- I saw in another post where you are going to run the 9.50 class-- Thats good to hear-- That will make 2 kz's then -- as long as I get the zx14 dragbike done we will hopefully be hitting most of th eprostars-- TG/Pro ET on the 14 bike and then ST ET and 9.50 on the kz. My cousin is trying to get rid of his zx10 and build a kz to run the 9.50 class too-- that would be sweet to see 3 kz's in that class next year.
1976 KZ900
2006 ZX14
08 KLX110
09 KVF750 Brute Force
1974 KE100
2006 ZX14
08 KLX110
1974 KE100
- StreetfighterKz
24 Nov 2007 06:08
smclem wrote:
9.50's seems like a good ET for a big bore Kz motor with a street tire. I'm really hoping to have it done by the Prostar meet at Norwalk in October. That's the goal anyways. Hopefully you and your cousin will be there and I'll have the bike done. That will be a great showing of the old Kz's to the Gsxr/Zx crowd.
Later, Doug
Doug-- looks like a lot of fun putting that together-- I saw in another post where you are going to run the 9.50 class-- Thats good to hear-- That will make 2 kz's then -- My cousin is trying to get rid of his zx10 and build a kz to run the 9.50 class too-- that would be sweet to see 3 kz's in that class next year.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- StreetfighterKz
26 Nov 2007 18:19
OK, I wanted to hold out but thought I should give some kinda update.
In the first pic of the thread you'll notice I had two tail sections stacked, well there was a reason for that.
I took the two and sectioned and trimmed and cut and rejoined to get a stock looking tail that's about 4-5" longer that a stock one.
I've tried making a couple fiberglass copies but haven't got it down yet.
Enjoy!
later, Doug
Enjoy!
later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- StreetfighterKz
26 Nov 2007 18:20
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
