My '76 z900 'Strip-fighter...sorta
- StreetfighterKz
Re: My '76 z900 'Strip-fighter...sorta
26 Nov 2007 18:21
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- OutlawGPz
- smclem
- www.osrbikes.com
27 Nov 2007 07:44
Yeah 3 old kz's whoopin up on the new bikes is gonna be fun-- I am hoping i don't have to rob any parts off mine to build the new dragbike but that will depend on the money. The look on the busa guys faces when they get drug by a kz is priceless-- I love it! Let me know if you need anything to get that baby done so we cna have all 3 there by norwalk.
1976 KZ900
2006 ZX14
08 KLX110
09 KVF750 Brute Force
1974 KE100
2006 ZX14
08 KLX110
1974 KE100
- mark1122
- Keep twisting it
27 Nov 2007 08:09
what kind of times does a stock busa put down ?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- StreetfighterKz
27 Nov 2007 08:35
www.dragbike.com/dbnews/anmviewer.asp?a=3489&z=3
With a very very good rider and some mods an '08 can run 9.30s.
But a completely stock '08 runs 10.0s with an average 200lb rider and runs 9.70s with a smaller very good rider.
later, Doug
later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- RollingStock
27 Nov 2007 15:21
put u also got to think about the prostar riders.. i know 3 personal..
mikey slow.. hes weight what 115-125lbs?..
johhny turbo weights more but can build and ride a bike really good.
and vic duno his lastname haha.. hes weight like 120lbs..
iv seen vic pull low low 9s on a newer gsxr1000 with just a pipe and filter..(i put the frontend on and helped with everything else.. so not going by hear say)
heres a pic... stock wheel base
sorry to highjack ur thread...
Post edited by: RollingStock, at: 2007/11/27 18:27
73 z1900 street nitrous drag bike(powered but honda)
83 kz750 turbo street fighter project
- StreetfighterKz
01 Apr 2008 14:46 - 01 Apr 2008 14:48
I made some of my bracing pieces recently. I used the PMC and Kosman kits as the foundations but eliminated some of the braces that were meant for bikes with twin shocks. I still need to make a few of the plates for around the steering neck and the two underneath the rear of the tank where the three backbone tubes meet.
I'll be adding a couple braces for the mono-shock mounting points (represented by the masking tape in the pics). The upper brace will be 1"x2"x0.12" rectangular tubing and the bottom brace will be 1.125x0.125" round tubing.
I found a guy who had a drawing for the stock Gsxr suspension geometry so I made some metal templates out of 1/16" steel with the holes in the right spots. I was going to use the stock centerstand brackets like Klasmo does for their bolt on mono-shock kits but the bottom linkage didn't line up so I made some brackets that have the same shape as the center stand brackets to weld on when I put the lower brace in.
The upper shock mount tabs are a work in progress. I intentionally made them too long/so when I have the new cross brace in I can trim them to size. The upper and lower tabs are 1/4" steel.
I'll figure out dog bone length later on when I have everything tacked together.
I also should be recieving the MIG I ordered this week sometime so I can tack everything together. Before final welding I have to weld on side cover D-zus tabs, figure out all the tabs needed for the electronics etc., passenger peg mounts, have a new rear subframe bent for my extended tail, etc. etc. etc.
I think that's about it for now.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 01 Apr 2008 14:48 by StreetfighterKz.
- StreetfighterKz
01 Apr 2008 14:49
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- StreetfighterKz
01 Apr 2008 14:50
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Bad Kaw
- Flying Squirell
03 Apr 2008 12:47
Waaaaaaaaay cool,
Please keep it comin'!
-KR
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- StreetfighterKz
13 Apr 2008 06:33
Little more progress. I got my welder and made my first real weld on the project. It's not much but its progress.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- StreetfighterKz
13 Apr 2008 06:42
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
