My '76 z900 'Strip-fighter...sorta
  • StreetfighterKz
  • StreetfighterKz's Avatar Topic Author
Re: My '76 z900 'Strip-fighter...sorta
28 May 2008 18:46
#216492
A little more progress.
I found a new use for old head nuts although I don't know if I'm too thrilled about the final product. Please let me know what you think as I can always grind them off.
BTW, if anyone has a lead on a left passenger peg and lock mechanism for a '01-02 Yzf-R1 I need one. I have the bracket but didn't get the peg.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
08 Jun 2008 13:37
#218746
That looks real good. Nobody sees the inside anyway...plus, you're gonna put a little more meat on those welds aren't ya?
You can put after-market pegs on your brackets...plus eBay has older R1 passenger pegs all day long for not much moo-lah.
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • StreetfighterKz
09 Jun 2008 04:42
#218895
-KR
Everything that I've welded to the frame will be TIG welded before powder-coating.
I spent 7 hours in the garage on Saturday and got a little more progress done. When I get a chance I'll post the pics.
1979 z650 Resto-Mod
2018 Z900RS
  • StreetfighterKz
10 Jun 2008 08:53
#219124
Little by little....
When I bought the GS headlight someone drilled a hole in it, probably for a switch....
So I found some sheet metal (in the form of an old Blazer gas tank I've had laying around for a couple years.)
Some cutting and trimming resulted in this...
About 5 rounds of tack welding and passes with the flap wheel ended up with this...
I wanted to get the light as tucked in as I much as I felt was possibly but because of the layout of my dash and shiftlight the bucket now needed a little cutout for the bottom of the shiftlight. So out can the cutting wheel and files...
With the headlight able to be tucked in close to the dash and above the steering damper headlight brackets were in order. I borrowed the idea from Kawasaki itself. Some of the later LTDs had similar headlight mounts although they were a little more complex. I used some spacers I had laying around and picked up some 1/4" steel rod from the local lumber store and got to work. Making the first bracket was hard enough without a bender of any sort. Try making an exact mirror image not easy to do.....
Looks like I got the look and position right...
Until this weekend....
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
10 Jun 2008 12:47
#219163
U did a fab job on filling the hole in the light Doug. way to go .How did u cut the circle?Drill saw?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • StreetfighterKz
10 Jun 2008 17:56
#219227
Just used tin snips and roughed a circle out and the little by little used the tin snips and then to a file to knock off the corners.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
11 Jun 2008 18:32
#219459
Good craftsmanship! And I love those big giant GS headlights, too! Keep up the good work.
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
  • cmmman
  • cmmman's Avatar
11 Jun 2008 22:51
#219534
I like the extended tail. How much bigger is the GS headlight?
1977 KZ650B, modified.
  • StreetfighterKz
12 Jun 2008 04:31
#219568
The kz measures 7" across the lens and the GS one I have measures 8".
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • StreetfighterKz
20 Jun 2008 13:53
#221186
Last weekend's progress pics....
Finished up the bracing...
Clearenced the frame a little. The tubes will be heated and flattened a little before powdercoating.
Gusseted the lower linkage tabs...
Hopefully I'll get to work on it this weekend but time looks a little tight.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
20 Jun 2008 16:19
#221206
Great work Doug.B)
I'm sure all that work will pay off with great handeling.are u going to add braces from the top rails down to the front rails? I've seen it on a few in pics and always thought it would help.the neck has to take soo much torque and stress, specialy with a modern front end.
Keep up the good work man.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Zedone
  • Zedone's Avatar
20 Jun 2008 22:08
#221276
I agree, great work! Cheers, Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
