My '76 z900 'Strip-fighter...sorta
- Bad Kaw
- Flying Squirell
Re: My '76 z900 'Strip-fighter...sorta
30 Jun 2008 21:04
Great stuff!!
-KR
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- StreetfighterKz
20 Jul 2008 14:46
Pics from a couple weeks ago...
Got the side covers mounted. The lower mounts will be finished after the braces are welded in which has to be fitted after the cross brace is finish welded. iconwhistle The covers were originally suppose to be bolted on but I though that would look kinda tacky so I enlarged the holes to take D-zus fasteners. I cut off the stock cover mounts a few years ago so I kinda mocked everything up and mounted the covers where they looked like they should go.
You might have noticed the new ignition switch location in the last pic. Its out-of-the-way yet accessible. I made a plate to mount the switch and used a spacer that I notched to keep the switch from turning and space the switch so it doesn't stick too far out. Before I mounted the plate I added a small shield to keep back-fires etc. out of the switch.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- mark1122
- Keep twisting it
21 Jul 2008 08:18
Way to go Doug. Your are taking the time to add all those small details that will set your project high on the pedistal.I love watching your progress. Keep up the good work.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Bad Kaw
- Flying Squirell
27 Jul 2008 20:31
Doug,
This is some really good work, I'm loving the detail photos, keep it up!
-KR
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
70 Kawasaki KV75
- jimmybon
05 Aug 2008 04:05
the seat looks "way cool"
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
- StreetfighterKz
06 Aug 2008 09:08
Little by little....
This is going to be my electrical panel. The shape is finalized I just need to make the mounting tabs and figure out how/where all my electronics are going to go. The panel is shaped to follow the frame and to be slightly smaller than my side cover so that it's hidden.
I also had an idea about how to vent my crankcase. Summit Racing sells weld on aluminum bungs for AN fittings. I calculated that a -8AN fitting (~.45" ID) will flow almost twice what the stock breather (~.35" ID) can. I'll end up drilling and welding the bung to the stock breather housing. This leaves the stock breather unused and it needs to be plugged so....
Found an old brake rotor bolt that fits the ID of the stock breather perfectly. So I cut off the unneeded threaded part.
Some welding and grinding....
Compared to a stock breather...
I know that there isn't a lot to report but I haven't had a lot of time lately. I guess that a little progress is better than no progress.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Bad Kaw
- Flying Squirell
18 Sep 2008 21:20
Man I LOVE guys that just make what they want...hahaha! That is sooooooooooo cool!
78 Kawasaki Z1R
70 Kawasaki KV75
70 Kawasaki KV75
- StreetfighterKz
19 Sep 2008 05:23
Bad Kaw wrote:
I work with what I have, make what I can't buy, and adapt something to what I need.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- PLUMMEN
19 Sep 2008 09:40
looking good,i need stuff like to keep me creeping along ever so slowly on my projects!
- Bad Kaw
- Flying Squirell
19 Sep 2008 16:14
PLUMMEN wrote:
Yeah, me too! But your projects tend to make a LOT of power, so you'd better go slow, eh?
looking good,i need stuff like to keep me creeping along ever so slowly on my projects!![]()
78 Kawasaki Z1R
70 Kawasaki KV75
70 Kawasaki KV75
- Bad Kaw
- Flying Squirell
19 Sep 2008 16:16
StreetfighterKz wrote:
It is for this reason, sir, that you are indeed "The Man". It's cool...this puts you in the Solumnruss, Plummen, Steele, etc - Catagory...it's a good place to be. By all means: drive on with your bad self.
-KR
Bad Kaw wrote:Man I LOVE guys that just make what they want...hahaha! That is sooooooooooo cool!
Later, Doug
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
70 Kawasaki KV75
- StreetfighterKz
28 Sep 2008 09:27
Well, like all projects something major is going to change and for me it's going to be a new rear rim and new front end setup.
About a month ago there was a listing on the Craig's list for a pair of '94 Gsxr750 fork legs and a 'Busa rear rim setup up for $100 a piece. A few weeks ago I decided to go with a 6" rim instead of a 5.5" so I can get a flatter profile with the 190 tire Shinko I picked up. I e-mailed the guy figuring that the lot was sold already. Tunes out that he forgot about listing them and we negotiated a deal.
After $150 and 1 speeding ticket here's what I got.
The forks will make mounting my '95 Gsxr750 wheel a whole lot easier. I won't have to have a custom axle made. I will have to get a set of '01-'03 Gsxr750/1000 triple clamps. The newer clamps will let me retain the steering stabilizer where the '93-'95 clamps wouldn't. Then I have to figure out what to do since I already had my gauge mounts welded to the 600's upper clamp.
I'll also change a few things on my swingarm extensions and use the 'Busa axle and brake hanger etc. I'll have to machine the 'Busa sprocket carrier to fit everything in the swingarm but I would have to do that anyway with the 5.5" rim I had.
I also finished my electical panel and made a custom battery box for the Oddessey/FBG battery I'll be running.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
