My '76 z900 'Strip-fighter...sorta
  • StreetfighterKz
  • StreetfighterKz's Avatar Topic Author
Re: My '76 z900 'Strip-fighter...sorta
26 Jan 2009 09:13
#260281
big hurdle for me was an extended rear frame section to clear the tire with the extended arm and mount my extended tail section. The original frame sat over top of the tire when I mocked up the arm. I had designed a rear section that follows the bottom of the tail section but after talking to a race car chassis for a while about it, my design was not feasible without the extra expense of having to buy a special mandrel ($300). I took it upon my self to figure it out and work with what I have.
I couldn't really find a good place to buy metric tubing to match the stock frame section tubing so I ended up getting standard size tubing. I went with a piece of 3/4"x .065" wall tubing as it's smaller than 20mm and 7/8" was too big OD to slip into the stock frame tubes. To make up the difference in the 20mm ID of the stock frame and the 3/4" OD of the new rear frame section I needed to make spacer sleeves. I was going to use a section of the original rear frame section and file the ID to match the 3/4" OD of the tube but I realized that it would take lots of effort and I couldn't guarantee I would end up with an even wall thickness.
Here's my solution. I found a metal divider from a metal desk that was about the right thickness I needed. I cut the sheet into strips and formed it around a piece of 3/4" tubing cutting the excess off as need so the ends wouldn't overlap at the seam.
Next was to start on the frame section. I started by slipping sections of the 3/4" tubing into my new sleeves and then the sleeves into the frame....
I used a part of the stock frame section to come up with the main hoops as bending a new piece wasn't economical. I think it turned out OK enough for me. It's not the one piece frame section I was wanting but I think its a fair compromise. All that needs done is final welding (obviously) and taillight mounting tabs as well as the tail section mounts and a brace for the rear of the seat.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • PLUMMEN
  • PLUMMEN's Avatar
26 Jan 2009 09:32
#260282
my extended tailpiece is going to be around 3" over but im adding the length in the area behind the stock rear mount so i shouldnt have to extend my frame to mount it.once iget mine mocked up as rolling chassis ill make a plate to mount my fender back using the stock location as one of the mounting points.i plan on chopping a stock steel rear fender in half and widening it it to clear a 180-190 rear tire and replating it to really have people scratching their heads,i might also extend the front of the fender so theres not a gap in front of it when i move it back.B)
  • StreetfighterKz
27 Jan 2009 07:51
#260452
In the background of the one pic you can see one of my fiberglass mold rejects that I'm using for mockup. It's part of the reason that I needed the longer rear section.
You have a good idea for the rear fender. Maybe I can get one of the wide fiberglass ones made by Beasley. I'll have to use a stock one for mockup. Most likely, I won't like the look so you can have it all to yourself.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • PLUMMEN
  • PLUMMEN's Avatar
27 Jan 2009 09:22
#260462
ive got one of those fiberglass kz style rear fenders someplace i bought years ago and didnt use it.anywap i want to widen a steel one a little bit so i can plate it and hang a stock z1 tail light on it to complete the illusion of being origional.theres lots of ways to reel in the sportbike fish,especialize if you catch em with shiny little stock looking details !:laugh:
  • StreetfighterKz
27 Jan 2009 09:31
#260467
Yeah, well, I think the 4-9" over adjustable swingarm and mono-shock is already going to blow that illusion for me.:woohoo:
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • PLUMMEN
  • PLUMMEN's Avatar
27 Jan 2009 10:06
#260475
most guys think monoshocks are origional!:woohoo:
  • StreetfighterKz
29 Jan 2009 07:44
#260819
Is this thread worth carrying on? It seems like I only get a few responses from the same people. I know I jump around on the project alot so sometimes it's hard to follow but the basic concepts are there.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
29 Jan 2009 08:13
#260820
Keep it up. This is one of the threads I always check.
Build Thread
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
30 Jan 2009 19:04
#261004
HOLY CRAP man! Save the thread! Tons of us watch, but don't chime in. Winter slows down most people, those who can carry on, do...the rest of us set back and watch in appreciation.
I like your build a ton...keep the thread, man!
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • PLUMMEN
  • PLUMMEN's Avatar
30 Jan 2009 22:11
#261038
keep it coming,gives my sorry ass motivation to carry on!B) B) B) B) B) keep posting your progress and ill keep posting mine and well see who can kit the most hits.the old school turbo or the new tech sportbike monster kz,that way we can keep all the monster motor bases covered.then one of these days when theyre both finished we can meet at a track someplace and bashem off,oughta be one hell of a showdown if either of em can get any traction!:woohoo: BIKER BUILDOFF on kzr.com,i feel a tv series coming on here!:laugh:
  • timebomb33
  • timebomb33's Avatar
30 Jan 2009 22:20
#261042
you guy's are so old it won't be tv it will be a radio series.
I THINK MY POWERBAND BROKE
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
30 Jan 2009 22:22
#261044
Oh yeah! Now, yer talkin'! In fact, that sounds like a logical place to have a KZRider Rally. I'm in!
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
