Advanced Search
Search Results (Searched for: gs swing arm)
Replied by Ed_in_Miami on topic Another KZP Project - APARTMENT build!
05 Jul 2017 06:48 - 25 Aug 2017 09:09
Ed_in_Miami's Avatar Ed_in_Miami
I have been working at a quicker pace than usual, trying to recover lost time, and take advantage of a week off of school.
So... taking advantage of my alone day on the 4th of July (poor wife had to work), I decided to setup my "home-shop" for a productive day at work.
Time to change the swing-arm bearings. Very hard to get out due to their thin profile... decided to get the dremel out
Out!
Replied by Tyrell Corp on topic Fork swap
05 Jul 2017 03:30
Tyrell Corp's Avatar Tyrell Corp
Other things to consider:
ride height -going from a 19 front to a 17
frame geometry/handling - castor and trail is altered, from the yoke offset as well as the fork dimensions
Side stand - may need lengthening
Matching wheels - can you get a matching rear in the swingarm? , rear sprocket offset ect...
Then making the ignition lock, instrument mountings, fairing etc all fit together, quite a lot of work involved.
Lowering front end was created by TwoCam
03 Jul 2017 18:52
TwoCam's Avatar TwoCam
Lowering your ft suspension is ok as long as you lower the back too. Here are some pics of what I did about 15 years ago. I bought 3" lowering kit for the ft forks..sure it looked wicked cool......BUT it liked the handeling!!!!! BIG time........ suspension bottomed out real bad......I had just over 1" of suspension travel...... not cool..so now that I'm getting the Green Monster back on the road...... having been sitting since 2013..... not by my choice either. So one mistake I did..... was lower her too much..... and also thought if I lowered it 3"....... I should cut the springs down too!!!! DOUBLE NEGITIVE!!!!!!!!)....... I just today took the forks apart....... took one spacer and cut it in half on my lathe..so now she is only 1.5" lower........ perfect with my 3" over swingarm project........ now I hope!!!!!! In my stuff....... I have some stock, unmolested springs.......
Replied by Kidkawie on topic 75 Z1
01 Jul 2017 07:05 - 01 Jul 2017 07:06
Kidkawie's Avatar Kidkawie
Tires, tubes, cables, oil and filters, carb kits, battery, plugs, clean/lube advancer, fork oil, brake fluid (rebuild if needed), clean electrical connectors, regrease steering and swingarm bearings, and fresh gas is all you should need.
Do not reapaint or throw anything away.
Replied by KZJOE900 on topic 75 Z1
01 Jul 2017 05:55
KZJOE900's Avatar KZJOE900
Two Thousand is very realistic to get it up and running. Not a full restore. But it depends on what you are defining as a restore. Back to OEM or just restored with time period modifications. If it was stored out of the elments you are way ahead of the game. If it has the original exhaust, then you are a lucky man. That alone can be worth a lot of money. But without even knowing anything about the bike, here is a quick run down of what you will most likey need with cost, if you most of the work yourself.
$200 to $300 Set of tires (mounted)
$150 Brake M/C and caliper rebuilt kits with front pads and rear shoes. Another $65if you replace the lines with SS lines.
$100 Set of four carbuertor rebuild kids
$170 New Chain/Sprocket/Lock Washers/Lube
$20 Valve adjust shims
$15 Valve cover gasket
$10 Petcock rebuilt kit
$10 Spark Plugs
$80 New Battery (AGM)
$10 to $100 Tank rehab (anywhere from vinger to a liner)
$200+ New title, registration and tags. This varies of course. I know some states have back fees which have to be paid.
This assumes the engine doesn't need anything other than maintence
This may get you to the point where it is rideable.
But I would also:
$15 + $35 Front and rear wheel bearing kits (modern AllBalls brand)
$25 New fork seals and fork fluid
$60 New steering head bearings (modern)
$120 Swing arm bering kit (modern)
For full restore OEM or other
$300 to $800 Paint: anywhere from basic one color to OEM paint job.
If it needs a new exchaust; anywhere from $350.00 for a low end 4 to 1 to $1200 for a four into four OEM exhaust.
Then lots of other nickel and dime stuff like SS bolts and nuts, replacing broken / missing items, etc, etc ...
Good luck
LONGER SWINGARM was created by TwoCam
30 Jun 2017 05:38 - 30 Jun 2017 06:45
im in the process of lengthening my arm 3 inches. in the process installing new pivot bearings.stock bearing is 28x22x16mm. on some swingarms you cam double up the bearings on each side for mor strength. my arm has a shoulder down in the tube so it was not possible. so had my bearing guy find me some that are 20mm wide. they fit perfectly!! its a german bearing, part number hk2220-b.
Replied by davido on topic Pivot Bolts
29 Jun 2017 08:56
davido's Avatar davido
When I changed my swingarm,I kept the original KZ pivot bolt (Fitting in the frame holes) and the hollow GSXR swingarm pivot bolt (fitting in the swingarm retaining the original bearings) and had a sleeve made up to take up the rest of difference..
Replied by diggerdanh on topic KZ400 Newb...
28 Jun 2017 05:58 - 28 Jun 2017 06:00
diggerdanh's Avatar diggerdanh
Nerdy wrote:
Polarity32 wrote: Good Evening gents..
I am thinking of a cafe or scrambler type build,
Look around here for someone named diggerdanh. He's doing a really nice scrambler build from a later KZ400.
Aww, :blush: - thanks for the kind word.
The standard KZ400 has great lines that is easily adaptable to custom styles: cafe, scrambler, tracker, brat, etc. The end result really depends on how much money you want to sink into it. Unfortunately you won't get that money back if you ever decide to sell it because the KZ400s don't bring the same kind of money the little Hondas (CB/CL 350/450) do. One of the reasons for that is the parts available aftermarket. You can find anything you can dream of for a Honda, quite a bit tougher for the little KZ. But it's not impossible.
First thing I suggest is maintenance, get it running well and ride it for a while before making changes. With only 9K miles you may not need to tear into the engine at all as long as there are no serious leaks. 90% chance the early engine (74-76) will leak but if it's only a drop here and there count yourself lucky and I would not mess with it until you have to. Typical things that will need to be inspected/replaced (depending on how long it has been sitting): Check valve lash, change oil (use a motorcycle specific oil), drain and replace fork oil, you may need to replace fork seals and caps, all cables, tires/tubes, battery, chain and sprockets, points and condenser, brake pads and rear brake shoes, possibly shocks, lube anything that needs lubed, etc. Make sure to check nuts and bolts are tight, especially for the wheels, swingarm, shocks, forks.
Where you go after that depends on what you want to do. If you're going to keep the stock carbs, they are the early ones that do not use rubber diaphragms (hooray!), then stick with the stock airbox configuration. If you want to go with pods, clear the triangle, etc. you'll be better off switching to Mikuni VM carbs and K&N/Uni filters rather than trying to run pods with the stock carbs. Though that carb swap does provide its own set of work but it has been done before so you ought to be able to get the jetting in a good starting range. If you want to go to a smaller lithium battery to be able to hide it better then you'll probably want to upgrade the stock electrics to treat the battery better, like swapping out the reg/rect for a newer combo unit from Oregon, Ricks or SparckMoto. If you swap in smaller/LED turn signals you'll have to change the flasher for an electronic one, There are a couple of options for electronic ignition if you are not a fan of points, I have opted for retrofitting the electronic ignition from the later 81+ KZ440s.
Handlebars - do whatever you like, easy swap. Rear shocks are a pretty easy swap, just determine what ride height you want and then spend the money that you want to spend. There are some Progressive options for fork springs if you want to upgrade those. I did not do it on my firs bike but I really like the changing from old rubber lines to braided stainless for the front brake. Lots of other things you can change like head lamp, the brackets that hold it, gauges, that really affect the look.
As mentioned before the biggest pain you will face is with finding custom parts to fit: things like seat, rear sets, etc. For that stuff you'll pretty much be on your own. You may find more help at cafe specific sites like DoTheTon.com.
Best of luck, keep us updated and post some pics when you get it! I'm sure we can help you work through what needs to be done.
Replied by Scirocco on topic Front End Swap
27 Jun 2017 09:56
Scirocco's Avatar Scirocco
This manual and hours of reading here in this great forum helps me a lot on my project bike fork swap.
I used a ZX9-R fork with 780 mm length
This browser does not support PDFs. Please download the PDF to view it: Download PDF
1985 GPZ 550 Rear wheel swap or swingarm swap... was created by w0lfman26
02 Jun 2017 16:25
w0lfman26's Avatar w0lfman26
So I have an 85 GPZ550 project that I've got a GSXR1000 front end on. After seeing the weight saving from the Gixxer wheel compared to stock, im looking at replacing the rear stock mag wheel with something more modern and lighter. Anyone know what wheel or if all else fails...swingarm and wheel combo that would work with little to no modification?
Displaying 771 - 780 out of 7255 results.
