LONGER SWINGARM
- TwoCam
LONGER SWINGARM
30 Jun 2017 05:38 - 30 Jun 2017 06:45
im in the process of lengthening my arm 3 inches. in the process installing new pivot bearings.stock bearing is 28x22x16mm. on some swingarms you cam double up the bearings on each side for mor strength. my arm has a shoulder down in the tube so it was not possible. so had my bearing guy find me some that are 20mm wide. they fit perfectly!! its a german bearing, part number hk2220-b.
Last edit: 30 Jun 2017 06:45 by Patton. Reason: change all caps to lower case
- TwoCam
Re: LONGER SWINGARM
30 Jun 2017 06:36
What are you doing to beef it up to prevent flex?
- TwoCam
Re: LONGER SWINGARM
30 Jun 2017 08:51
I HAVE A COUPLE IDEAS.....TO TUBE IN THE LOWER SIDE.......MY FIRST IDEA WONT WORK. THE CHAIN IS RIGHT IN THE WAY....I HAVE SEEN PICS OF WHAT OTHER PEOPLE HAVE DONE, SO I HAVE A FEW IDEAS.....WORK IN PROGRESS......
- TwoCam
- TwoCam
Re: LONGER SWINGARM
30 Jun 2017 09:04
My arm mod is on hold for now but you might get some ideas from Leon and the others.
kzrider.com/forum/5-chassis/600555-swing...zzr1200?limitstart=0
The following user(s) said Thank You: TwoCam
- TwoCam
Re: LONGER SWINGARM
30 Jun 2017 09:07
I TURNED DOWN THICK WALL TUBING ON THE LATHE, THEN BEVELED THE ENDS TO PRESS FIT INTO THE FACTORY TUBING, SQUARED EVERYTHING/CLAMPED UP AND STARTED TACK WELDING....HAD TO TRIM THE INNER FENDER, CUT OFF THE REAR FENDER, ALSO HAVE TO MAKE A MODIFICATION TO THE BASTTERY BOX, SITS TOO LOW........ILL TAKE IT OUT AND CUT ABOUT AN INCH OFF AND MAKE A NEW BOTTOM PLATE, THEN I SHOULD HAVE PLENTY OF CLEARANCE.
- TwoCam
Re: LONGER SWINGARM
30 Jun 2017 10:56
Did you clamp it down while welding? That's why mine is stalled. Off 1/8" at the back. I made a jig and will have to recut and weld it again.
- TwoCam
- TwoCam
