What size Piston kit to run with Mr Turbo kit 16 Jan 2017 13:17 #752316
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1978
jumbulias wrote: Thanks for the info. I will check that out when i Split the cases again. I forgot to put the clutch housing in. Did you have ape racing rebuild and weld clutch housing on yours?
Stock clutch basket. Polished the aluminum basket fingers so clutch doesnt stick , bind or chatter
9 plate clutch Action 4 ( A Bill Hahn Company )
Pusher bearing from APE
Shift bushing APE
Centrifical Lockup clutch ( Karata Glide )
HD springs Action 4 * probably not needed
Last edit: by Street Fighter LTD.
What size Piston kit to run with Mr Turbo kit 02 Feb 2017 13:46 #753502
  • jumbulias
  • jumbulias's Avatar Topic Author
  • Thank you received: 7
Got The Clutch basket back from Ape . Looks Great!! Back to work this Weekend
What size Piston kit to run with Mr Turbo kit 04 Feb 2017 06:49 #753631
  • jumbulias
Scored some parts for the Black Beast! It will be my
second build. Time to go work on my First Build.
What size Piston kit to run with Mr Turbo kit 04 Feb 2017 13:21 #753648
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
jumbulias wrote: Thank You!!!! Looks like I am back to the drawing board. Totally forgot about the clutch housing.. I thought about sending the clutch housing to Ape Racing to be be rebuilt with there heavy duty kit, looks like I will have time know. Thanks Again You saved me alot of time in the long run.
Been there, done that! cool build. following along.
What size Piston kit to run with Mr Turbo kit 04 Feb 2017 18:42 #753672
  • jumbulias
Got the clutch housing in. also got the pistons installed The cylinder head done by Larry C is next.
What size Piston kit to run with Mr Turbo kit 11 Feb 2017 13:31 #754114
  • jumbulias
Got a Little Bit done today. Installed Liska Idlers and Cylinder Head . Hopefully I can work on it tomorrow
Last edit: by jumbulias.
What size Piston kit to run with Mr Turbo kit 11 Feb 2017 13:40 #754116
  • jumbulias
Liska Idler and Tensioner
What size Piston kit to run with Mr Turbo kit 11 Feb 2017 19:12 #754135
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2635
Missing one? :whistle:
What size Piston kit to run with Mr Turbo kit 12 Feb 2017 03:12 #754139
  • jumbulias
Hello Steve Is this what you thought was missing?
What size Piston kit to run with Mr Turbo kit 12 Feb 2017 04:22 #754140
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1472
jumbulias wrote: Hello Steve Is this what you thought was missing?
The other idler that goes above that on it's pivot.
What size Piston kit to run with Mr Turbo kit 12 Feb 2017 07:25 #754149
  • SWest
  • SWest's Avatar
  • 10 22 2014
I have the same setup. I guess you left it off for the pics. There are two of them. That block is purdy.
What size Piston kit to run with Mr Turbo kit 12 Feb 2017 14:17 #754169
  • jumbulias
Thank You for the info. I appreciate it
