What size Piston kit to run with Mr Turbo kit 11 Jan 2021 08:05 #841523
  • jumbulias
  • jumbulias's Avatar Topic Author
  • Thank you received: 7
Looking for someone to make me a oil pump extension
Last edit: by jumbulias.
What size Piston kit to run with Mr Turbo kit 12 Jan 2021 05:41 #841563
  • jumbulias
Got ahold of Turbomaxx . He said they are making a few kits. He said it would be a few weeks.
What size Piston kit to run with Mr Turbo kit 22 Jan 2023 07:13 #879146
  • jumbulias
Putting together a oil cooler kit for the bike. What degree of fittings for the adapters on engine? 45,60,90 . Going over the top of engine with hoses.
What size Piston kit to run with Mr Turbo kit 22 Jan 2023 07:52 #879150
  • jumbulias
After looking at some bikes that AC Sanctuary built. I think I am going to side route the hoses. Looks alot better and easy.
What size Piston kit to run with Mr Turbo kit 22 Jan 2023 11:36 #879159
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1953
How about some current pictures of bike and new pieces
DD
What size Piston kit to run with Mr Turbo kit 23 Jan 2023 06:09 #879200
  • jumbulias
Oil cooler ,adapters hose etc on order. Oil cooler, hose and fittings are from summit racing.Should get those pretty quick. Had to order oil cooler bracket and engine adapters from webike.Wiill not be here until March. Pic is cooler I am getting.
What size Piston kit to run with Mr Turbo kit 10 Jul 2023 12:50 #887061
  • jumbulias
Got some parts today. Oil cooler.AC Sanctuary High pressure pump and fittings. Hope I get some time to work on it soon.
Last edit: by jumbulias. Reason: pics
What size Piston kit to run with Mr Turbo kit 10 Jul 2023 15:08 #887064
  • Injected
  • Injected's Avatar
  • Thank you received: 367
Is there any information in the instructions on what to expect for oil pressure? (interested to find out)
What size Piston kit to run with Mr Turbo kit 11 Jul 2023 00:46 #887079
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1441
I have a high capacity extended oil pump for my turbo build. ( in this pic with some of the other parts )
It's from Turbomaxx and delivers 30% extra flow.. No mention of any oil pressure rating but i think that PMC one is similar.
There are some other "Hi performance" pumps on the market for stock replacement which are to higher tolerances and put out 13% more.
Z1 Z2 Z1R Mk.II Z1000J/R Z1100GP GPz1100 KZ900 KZ1000 high performance Oil pump | eBay
Last edit: by zed1015.
What size Piston kit to run with Mr Turbo kit 11 Jul 2023 01:06 #887080
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1720
That is some serious "mechanical porn" I feel a future BOTM is in the making
What size Piston kit to run with Mr Turbo kit 11 Jul 2023 04:53 #887082
  • Injected
  • Injected's Avatar
A lot of cash for 30% more flow, I am guessing only really needed on a turbo build. If its flow rated then that probably means its not a great pressure increase over stock.
What size Piston kit to run with Mr Turbo kit 11 Jul 2023 15:41 #887128
  • jumbulias
