What size Piston kit to run with Mr Turbo kit 28 May 2017 17:22 #762984
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1972
Very Nice !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
What size Piston kit to run with Mr Turbo kit 29 May 2017 13:49 #763038
  • jumbulias
  • jumbulias's Avatar Topic Author
  • Thank you received: 7
Clutch Cover buffed out pretty nice. Used Menzerna buffing compound, It is the best by far!!
What size Piston kit to run with Mr Turbo kit 19 Aug 2017 11:47 #769250
  • jumbulias
Finally found a swingarm Looks nice with 180 tire.
What size Piston kit to run with Mr Turbo kit 04 Sep 2017 16:12 #770339
  • jumbulias
Off work this week Hope to get alot done. Here are some pics. Electronic Tach , Boost Gauge , etc.
What size Piston kit to run with Mr Turbo kit 05 Sep 2017 14:19 #770399
  • jumbulias
Found a spot to mount The Innovate SCG-1 Wideband Gauge , Made a little bracket that mounts to the Triple Tree. The fun part will be installing the wideband sensor.
What size Piston kit to run with Mr Turbo kit 05 Sep 2017 15:09 #770402
  • jumbulias
Made a oil catch in the front of the Swingarm. Welded 2 bungs on top 1 goes to low profile breather cover ,other goes to crankcase breather filter, and one on bottom for drain port.
Last edit: by jumbulias.
What size Piston kit to run with Mr Turbo kit 05 Sep 2017 18:25 #770415
  • Moderator
Love what Im seeing. Have you given any thought
to bracing the frame and getting stronger motor mounts
Dave B) B) B)
What size Piston kit to run with Mr Turbo kit 06 Sep 2017 05:21 #770442
  • jumbulias
Hello Dave Yes I have been thinking about it. I like the Pingle Motor mount kit and for the frame bracing either the Kosman kit or making it myself. Low on funds at the moment.
What size Piston kit to run with Mr Turbo kit 06 Sep 2017 10:11 #770460
  • jumbulias
Went ahead and ordered Pingle Motor mount kit . I also found a frame bracing kit from PMC Part # 74-0020 looks nice
What size Piston kit to run with Mr Turbo kit 07 Sep 2017 02:46 #770506
  • jumbulias
I went ahead and ordered The PMC Frame Kit . Should be here in a week
What size Piston kit to run with Mr Turbo kit 07 Sep 2017 05:30 #770510
  • Moderator
Glad to hear you are doing the frame and mounts . I would hate to see all that boost cause you grief
with a wobbling bike. Keep up the good work
Dave B) B) B)
What size Piston kit to run with Mr Turbo kit 07 Sep 2017 09:07 #770529
  • jumbulias
Thanks for all your advise . I really appreciate it.
