Re:What size Piston kit to run with Mr Turbo kit 05 Sep 2016 07:17 #741158
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1967
Julian_Boolean wrote: In the late 80s I knew someone who had a 1978 Z1000 with a 1400 big bore, turbo and nitrous, it made 236 bhp, he's probably still got it but I haven't seen him since 1989.
With that combo of size , boost and nitrous he could have made far more power if he wanted to :evil:
Dave B) B) B)
What size Piston kit to run with Mr Turbo kit 17 Sep 2016 13:04 #742626
  • jumbulias
  • jumbulias's Avatar Topic Author
  • Thank you received: 7
Finally found Akront 18- 5.75 rim for my project..Know looking for extended swingarm.
What size Piston kit to run with Mr Turbo kit 23 Nov 2016 12:46 #748754
  • jumbulias
Mr Turbo Kit finally done. Should get it next week. Man I am getting excited. Cant wait. Cylinder head done by Larry C looks great. Joe Hooper did the MTC 1197 turbo big bore kit , and all other machine work. Time to build!!!!!. I will post pics as i can. Godbless
What size Piston kit to run with Mr Turbo kit 23 Nov 2016 14:41 #748765
  • DFIGPZ
  • DFIGPZ's Avatar
  • Thank you received: 122
What about Crank, Trans, Clutch hub ?
1984 750 Turbo
What size Piston kit to run with Mr Turbo kit 24 Nov 2016 01:19 #748811
  • jumbulias
Done by Joe hooper Welded Crank and indexed, Milled main bearing cap for support, undercut Transmission, And I got a MTC Lockup clutch. and I will be using the Ape Cylinder and bearing studs. Tsubaki Cam Chain etc.
What size Piston kit to run with Mr Turbo kit 14 Jan 2017 15:30 #752196
  • jumbulias
finally got a little bit done today. Got the crankshaft, trans and cases put back together. and installed in the frame.
What size Piston kit to run with Mr Turbo kit 14 Jan 2017 15:32 #752197
  • jumbulias
more pics
Last edit: by jumbulias.
What size Piston kit to run with Mr Turbo kit 14 Jan 2017 15:34 #752198
  • jumbulias
Will be installing the block with the MTC 1197 Turbo pistons next
What size Piston kit to run with Mr Turbo kit 15 Jan 2017 05:40 #752227
  • Moderator
Awesome
I cant see clearly in your pictures if the oil pickup is set to be down into your rear deep pan.
Bad camera angle ?
Oil pickup should be about 3/4 of a inch above deep sump bottom
Keep up the good work !!
Dave B) B) B)
What size Piston kit to run with Mr Turbo kit 15 Jan 2017 06:39 #752233
  • JOE MKII
  • JOE MKII's Avatar
  • Thank you received: 25
Cool project, I always wanted to do a turbo but never have mostly because of the $$$$.
Looks like its being done well.
One question, I am new to KZ's so I don't now much, but doesn't the clutch hub have to go in before the cases are put together, or is it different with a lock-up clutch, or on different year KZ's
I believe its called "Oppositional Defiance Disorder"
What size Piston kit to run with Mr Turbo kit 16 Jan 2017 13:05 #752312
  • jumbulias
Thank You!!!! Looks like I am back to the drawing board. Totally forgot about the clutch housing.. I thought about sending the clutch housing to Ape Racing to be be rebuilt with there heavy duty kit, looks like I will have time know. Thanks Again You saved me alot of time in the long run.
What size Piston kit to run with Mr Turbo kit 16 Jan 2017 13:11 #752314
  • jumbulias
Thanks for the info. I will check that out when i Split the cases again. I forgot to put the clutch housing in. Did you have ape racing rebuild and weld clutch housing on yours?
