What size Piston kit to run with Mr Turbo kit 11 Sep 2017 19:02 #770781
  • KZ802
  • KZ802's Avatar
  • Thank you received: 13
Is that an old calfab extended gs1100 swingarm? or a new one made by motogpworks? also what hub is that?
1980 KZ750 LTDx2
1978 KZ1000 LTD
1976 KZ900 A
What size Piston kit to run with Mr Turbo kit 01 Dec 2017 13:52 #775390
  • jumbulias
  • jumbulias's Avatar Topic Author
  • Thank you received: 7
YesIt is a Old school Calfab. Hub is from Harley I believe. Thanks
What size Piston kit to run with Mr Turbo kit 01 Dec 2017 13:55 #775391
  • jumbulias
Got the Frame Brace Kit Tig Welded in. Here are are some Pics. Powder coating is next. Have to save up money for it.
The following user(s) said Thank You: Kray-Z
Last edit: by jumbulias.
What size Piston kit to run with Mr Turbo kit 03 Dec 2017 15:16 #775494
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
man this thing is turning out awesome. Following along.
What size Piston kit to run with Mr Turbo kit 19 Dec 2017 13:17 #776350
  • jumbulias
Thanks!!
What size Piston kit to run with Mr Turbo kit 19 Dec 2017 15:45 #776361
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
  • Thank you received: 107
Hey, just catching up to your fantastic high-end build today.....I'm awestruck. I'm also sort-of glad I won't likely meet with your bike at a stoplight where I live anytime soon......
As my son (then 12 yrs) once told me at the races, to quote - "Dad, I know your my dad and everything, and I love you and I am not supposed to hurt your feelings, but.... that guy made you look like you were going backwards...."
The following user(s) said Thank You: jumbulias
Last edit: by Kray-Z.
What size Piston kit to run with Mr Turbo kit 03 Feb 2018 05:15 #778135
  • jumbulias
Need help on gear ratio. What size sprockets are you guys running on turbo bikes? I found a 520 countershaft sprocket with the correct offset but it only comes in 18 or 19 teeth. I will have to have a custom sprocket made for the rear wheel which is 18 inch 180 tire. .Any help appreciated.
What size Piston kit to run with Mr Turbo kit 03 Feb 2018 05:27 #778136
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1972
With stock chain size I usually run 16 x 33 It will pull it fine . And makes motor boost with the load it causes.
Keeps bike very fun and easy on revs on highway.
Or stock gearing of 15 x 33 runs fine too.
Never needed to go the other way like a normally aspirated motor ( 14 x 35 ) NOT needed with turbo
Convert these numbers to 520 chain size ratios
Dave B) B) B)
What size Piston kit to run with Mr Turbo kit 05 Feb 2018 05:51 #778246
  • PaintWorkz
  • PaintWorkz's Avatar
  • Thank you received: 68
Stock gearing got me 162mph on the speedo, typical 10% off or 147mph on the ECTA timers
www.paintworkz.com
84 Gpz900 street
77 KZ 1325 Turbo Dragbike project
79 CBX Pro Stock projects (2)
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
What size Piston kit to run with Mr Turbo kit 05 Feb 2018 06:52 #778248
  • GregZ
  • GregZ's Avatar
  • Thank you received: 88
PM sent
What size Piston kit to run with Mr Turbo kit 01 Apr 2018 14:55 #781115
  • jumbulias
Got A Deep Pan. Should Refinish Well. Know looking for oil pump extension. Hopefully back to work on it soon !!!
What size Piston kit to run with Mr Turbo kit 01 Apr 2018 15:25 #781117
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1469
jumbulias wrote: Got A Deep Pan. Should Refinish Well. Know looking for oil pump extension.
Nice find.
I have one just the same.
I scored an unused Turbomaxx billet pump for mine in a trade
30% extra flow but they are not cheap new.
The stock pump is easily extended though if you have access to a lathe.
Those pans have excellent baffling so no need for a rear pick-up.. Just extend downwards.
The early pumps can have it as a bolt on mod and the later ones a light press fit extension with 3 tig spots to make sure it stays put.
Last edit: by zed1015.
