kz750 custom swingarm fab
  • 80B4
  • 80B4's Avatar
Re: kz750 custom swingarm fab
30 Nov 2014 18:14 - 30 Nov 2014 18:21
#655010
I
1980B4 1000
1978 Z1R
1978 B3 750
Last edit: 30 Nov 2014 18:21 by 80B4. Reason: photos won't go!
  • 531blackbanshee
  • 531blackbanshee's Avatar Topic Author
  • Vendor
  • Vendor
01 Dec 2014 05:43 - 01 Dec 2014 07:24
#655035
the underbrace was discussed earlier in the thread.
bottom line,
i did it the way i did because that's the way i liked it.
Last edit: 01 Dec 2014 07:24 by 531blackbanshee.
  • 531blackbanshee
  • Vendor
  • Vendor
01 Dec 2014 07:24
#655045
got the subframe finished out .
now to work out battery box location/fab/mounting and compressor mounting and bracket fab.
  • NakedFun
  • NakedFun's Avatar
01 Dec 2014 09:05
#655056
Looks good Leon. I assume it will have a fiberglass tail/bubble behind the seat? Looks like that will be about the only spot for the compressor....unless you are going to have side shields for the subframe section? Also you can run a tiny Shorai or Ballistic Li-On battery which can be mounted sideways, upside down, he'll even rectal-ly..... Anyways you could hide it anywhere. You also still need to find where the rest of the electrics go as well right?
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • 531blackbanshee
  • Vendor
  • Vendor
01 Dec 2014 11:55
#655065
cory,
fortunately there is a nice spot to hide the compressor above the swingarm pivot in between the frame sides.
i just have to fab the bracket.
the customer has plans to make his own seat/tail combo out of fiberglass.
so he gets to decide what battery and where it will be located.i just have to fab the box and mount it.
same with the elctronics.
  • Bovine
  • Bovine's Avatar
01 Dec 2014 12:17
#655068
Leon,
Keep up the good work, and please keep posting pics, its great to see this project progress...
Rod...
  • 80B4
  • 80B4's Avatar
02 Dec 2014 05:46 - 02 Dec 2014 06:59
#655136
Here are the photos of the airbox I made for my 1978 750 twin. It will use a K&N RU2420 or RU2430 filter. there is lots of room for airflow internally. The wall thickness is 3mm. (.118in.).
1980B4 1000
1978 Z1R
1978 B3 750
Last edit: 02 Dec 2014 06:59 by KZQ.
  • Bovine
  • Bovine's Avatar
02 Dec 2014 05:56
#655138
Pics didn't post?
  • 80B4
  • 80B4's Avatar
02 Dec 2014 06:29
#655139
Ill try again later
1980B4 1000
1978 Z1R
1978 B3 750
  • Bovine
  • Bovine's Avatar
02 Dec 2014 06:50 - 02 Dec 2014 06:57
#655140
okay.... I've tried to post pics but for some reason I can't get them to show up?
Attachment _3.jpg not found
Last edit: 02 Dec 2014 06:57 by KZQ.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
02 Dec 2014 07:06 - 02 Dec 2014 07:08
#655141
Below the box where you enter the text of your post is an "Attachments" box. Click add file and then browse till you find the pic you wish to display, Then click the submit button and your picture will be displayed as a thumbnail. To view the thumbnail just click on it and the full size pic will display. Your problem may be with the file size. The upper limit is 2 megs, don't remember the pixels by pixels limitation just now. If you click the insert button your picture will be inserted in your post and will have to be downloaded every time someone else opens your posting. I added some pics of an exhaust baffle in your posts above. Each of you can edit them out.
Hope this helps.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: 02 Dec 2014 07:08 by KZQ.
  • Bovine
  • Bovine's Avatar
02 Dec 2014 07:13
#655142
Thanks Bill, I'll try your instructions when I get more time. I'll bet your right about the sizing.... By the way, this is a really GOOD site. I've found nearly every bit of info I need. And if I can't find it I know all I have to do is ask! Thanks for the work all of you do!
Rod
