kz750 custom swingarm fab
  • Bovine
  • Bovine's Avatar
Re: kz750 custom swingarm fab
13 Nov 2014 13:51
#653610
Yikes 80Bf, Ah, have to say trick cases!! Nice work, I'm afraid to ask how many hrs. you have in the machine work!! The KZ swing arm set up is very nice, those shocks look long? eye to eye what are they 14"??? what brakes are you going to run? Will they bolt right up to the stock hangers or will you have to mill those mounts as well.. Are those alloy engine mounts?
I really like this site, there are some very creative folks on here.. Great ideas, and some great people willing to share there experiance..PRICLESS!
The machine work on your YZF is eye candy very nice. Like I said there are some very talented folks on here, Its good to know there are others who want to make a good thing ( older bikes ) that much better. Thanks for the pictures!
Rod P.
The following user(s) said Thank You: 80B4
  • NakedFun
  • NakedFun's Avatar
13 Nov 2014 14:33
#653614
Bovine wrote: Yikes 80Bf, Ah, have to say trick cases!! Nice work, I'm afraid to ask how many hrs. you have in the machine work!! The KZ swing arm set up is very nice, those shocks look long? eye to eye what are they 14"??? what brakes are you going to run? Will they bolt right up to the stock hangers or will you have to mill those mounts as well.. Are those alloy engine mounts?
Rod P.
Shocks are stock ZRX1100/1200 shocks. Think they are around 13.5-13.75" eye to eye IIRC. Info is available via Google.
The engine mounts are aluminum ones from Pingel, but D&G Chassis and PMFR also make the same mounts for the Z/KZ bikes.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
The following user(s) said Thank You: Bovine
  • Bovine
  • Bovine's Avatar
13 Nov 2014 14:46
#653618
Thanks Cory..
  • 80B4
  • 80B4's Avatar
13 Nov 2014 14:55
#653619
Rod,
The ignition mount / cover weren't bad, the clutch cover took some time. They both are about 70% programming and 30% machine time. Those are zrx 1200 shocks and they are over 1" longer then the oem. The rear brake will be an early r1 mono block and the front is a 3rd gen. YZF monoblock. The front fork is a 41mm KYB cartridge unit from a 97-07 YZF600R and the calipers are bolt-on. Race-Tech sells everything needed to make the forks work on a heavier bike. Pingle makes the motor mount kit, the oversize bolts are hard to find part.
My 750b will get the same forks, brakes and wheels. Those old twins are interesting bikes. No other Japanese manufacturer has made anything like it. I have this way of turning a $200 bike into something much more expensive!
Ride Well,
Jon
1980B4 1000
1978 Z1R
1978 B3 750
  • NakedFun
  • NakedFun's Avatar
13 Nov 2014 15:19
#653621
80B4,
You need to sell those covers......some of us would be willing to have sets made!
Cory
1976 Kawasaki KZ900
  • Bovine
  • Bovine's Avatar
13 Nov 2014 15:22
#653622
Your right Cory, he does!!
  • Bovine
  • Bovine's Avatar
13 Nov 2014 15:25
#653624
Jon, thanks! Please post the air box pitures when possible! Yep I really like the KZ twins, but I'am a twin guy any way.. thanks for sharing your work.
  • 80B4
  • 80B4's Avatar
13 Nov 2014 15:36
#653626
I'm working on the counter shaft, charging system and starter motor covers too. They will be the best I can do, so they will not be inexpensive. I want to make a clutch cover with a window, but I haven't designed one that I like yet.
1980B4 1000
1978 Z1R
1978 B3 750
  • NakedFun
  • NakedFun's Avatar
13 Nov 2014 16:54
#653630
80B4 wrote: I'm working on the counter shaft, charging system and starter motor covers too. They will be the best I can do, so they will not be inexpensive. I want to make a clutch cover with a window, but I haven't designed one that I like yet.
Nothing on my bike is inexpensive... Lol. I machine everything I can, but had to farm out my cush drive plate even though I designed it since I did not have access to a rotary table.
Cory
1976 Kawasaki KZ900
  • 80B4
  • 80B4's Avatar
13 Nov 2014 17:20
#653631
Cory,
That cush drive plate is a nice part! I am doing a spoked rear wheel for for my wife's RD400 and the elastic sprocket mounts you use are very interesting. Can I ask what they are and where you found them?
Thanks!
1980B4 1000
1978 Z1R
1978 B3 750
  • 80B4
  • 80B4's Avatar
13 Nov 2014 18:50
#653641
Rod,
The police swingarm is 9 1/4 in wide at the pivot, 20 1/2 in. Pivot cl to cl of the axle when the axle is at the center of the adjustment. 10 1/8 in outside of the thick tabs at the lower shock mount.20mm OD axle. 16mm.pivot bolt.
Jon
1980B4 1000
1978 Z1R
1978 B3 750
  • NakedFun
  • NakedFun's Avatar
13 Nov 2014 18:50 - 13 Nov 2014 18:51
#653642
80B4 wrote: Cory,
Thanks!
Thanks for the nice words. My cush drive setup uses Ducati cush pins. You can find them on EBay. Just search for "Ducati Cush Pins." They use either 5 or 6 cush pins that are the same. They use a 10mm stud. Now if you go that route, you will still need a center sprocket disc like I machined to take the shear force of the drive chain. I also used Harley Davidson hubs due to their symmetry and availability of options.
Cory
1976 Kawasaki KZ900
Last edit: 13 Nov 2014 18:51 by NakedFun.
