Megasquirt / Microsquirt a KZ
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
Re: Megasquirt / Microsquirt a KZ
16 Jan 2012 17:28
#498348
I got to quit looking at this, it's getting me upset real bad. I just can't take much more pressure, I'm going to have to do this to the turbo bike or I'm going to always regret it and I'm holding you guys responsible! :evil:
Les
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
16 Jan 2012 17:32
#498350
jydog wrote: Making progress...
holy crap jydog! :woohoo:
i did not realise that you were building an electric bike :silly: .
whoo thats a bunch of wires :sick: .
i hope you figure out where they all go :P .
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
16 Jan 2012 20:10
#498365
jydog wrote: What size fuel line should I be using? 1/4 or 5/16?
i ran 1/4 on my 1135cc motor ,with vm33 carbs no problems.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Boostable
  • Boostable's Avatar
16 Jan 2012 23:04
#498396
That is a lot of damn wires... lol Nice to see the progress.. Once you get all those wires figured out then you can help me figure mine out.. lol
Hope to have the engine in SOON!!
~Jack
1982 KZ1000 J2 ~ Project (Street Fighter - Project Section)
1976 KZ900 - Daily Rider
  • ramtough_63
  • ramtough_63's Avatar
17 Jan 2012 01:52
#498416
Oh MY!
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
  • jydog
  • jydog's Avatar Topic Author
17 Jan 2012 18:59
#498488
The wiring dosen't seem all that bad. You just have to pick a spot and work your way out. I swaped in a zx6 junction box also for the blinkers and fuses etc.. so I've got 3 wiring diagrams to graph togther.
Completed so far:
ecu mounted
fuel pump mounted
map sensor mounted
wired the main relay for power to the ecu and can read it from my laptop
wired the fuel pump to ecu and power relay used AN -4 fitting for pump so I will probably
be using a 1/4 line
next, wire the injectors. Ok ol wise ones of the board. The firing order is 1243 with left coil firing 1 & 4 and right 2 & 3 wasted spark. Am I getting this right so far?
The ecu has two banks to batch fire 2 high impedance injectors each. The question is should the batches be paired 1&4 and 2&3?
81 KZ1000 LTD
Griffin GA
  • Boostable
18 Jan 2012 01:04
#498570
I assume based on your configuration that you are using a single crank trigger or missing tooth setup correct? If so, then you are on the money with the waster spark setup. If your using more then one trigger then you have options.
Pairing on the batch fire is correct as well. (1 & 4 and 2 & 3) Would like to see a sequential option, but not supported for our config would probably just complicate things anyway.. lol
~Jack
  • steell
  • steell's Avatar
18 Jan 2012 03:09 - 18 Jan 2012 03:14
#498598
Boostable wrote: I assume based on your configuration that you are using a single crank trigger or missing tooth setup correct? If so, then you are on the money with the waster spark setup. If your using more then one trigger then you have options.
You can do sequential injection and ignition with an MS2.
I think you can do 4 high impedance injectors per bank, for a total of eight.
The following is about the new MicroSquirt, but I'm pretty sure the old one was the same.
The fuel injector drives will max out at 5 amps each, enough to drive one low-impedance (or 4 high-impedance) injector per bank.
MicroSquirt at DIY autotune
Last edit: 18 Jan 2012 03:14 by steell.
  • Dave Sloan
  • Dave Sloan's Avatar
18 Jan 2012 06:22
#498608
Sorry, I have not been on hte forum for a while and forgot abou this thread :blush:
My return is on the right hand side of the tank a bit behind the TBs so that the return pipe from the fuel reg is underneath it.
I will take some pics on the weekend.
I seem to recall that I have the bike set up as a 2 cylinder because of the wasted spark. There was an issue with the ecu reading the revs at 1/2 speed or was it double?Bugger memory is a bit shot :dry:
I run the gpz11 injector that are low impedance and have used both the flyback board and currently running resistors, both ways work fine. The flyback board is in my first ecu that is set up for ignition. The one I am using at the moment is running fuel only. 2.2board ms1 extra code.
Z650B2 - Injected
  • jydog
18 Jan 2012 07:30 - 18 Jan 2012 07:56
#498611
I am going to try to start by using the pickup off the negative on the coil for fuel only and leave the stock ignition in place. Is the 81 KZ1000 ignition considered CDI? if so I can not do this it will damage the optisolator. Somebody please chime in if you know the answer to this.
Steell, I am pretty sure you can only do sequential injection with a 2 cylinder with microquirt v3 since it only hase 2 individual banks.
Dave, anything you can remember or take pictures of would be great. Im hoping to leave a record here of my trial and error to make it easier for others
81 KZ1000 LTD
Griffin GA
Last edit: 18 Jan 2012 07:56 by jydog.
  • 531blackbanshee
  • Vendor
  • Vendor
18 Jan 2012 10:41
#498633
thanks for documenting this here jydog.
i am one of the people following along that has had an interets in f.i. but nowhere near the sack to try and jump in and set one up.
so seeing you guys do it is helping build my confidence.
some :lol: .
  • Boostable
18 Jan 2012 13:48
#498653
531blackbanshee wrote: thanks for documenting this here jydog.
some :lol: .
How about this Leon.. You weld in our new gas caps and we will help you setup the EFI.. ;)
~Jack
