Megasquirt / Microsquirt a KZ
  • Boostable
  • Boostable's Avatar
Re: Megasquirt / Microsquirt a KZ
10 Nov 2011 09:50
#487858
Thats great, keep us posted on the progress, and maybe we can see copies of the map. :)
My TB's arrived today, so I may do some bench testing this weekend.
~Jack
1982 KZ1000 J2 ~ Project (Street Fighter - Project Section)
1976 KZ900 - Daily Rider
  • jydog
  • jydog's Avatar Topic Author
24 Dec 2011 13:16
#494545
Does anyone see why the fuel check valve would need to be in the tank like the gpz for efi or would it be just as well to have it located in the line using something like the fitting in this link?
www.summitracing.com/parts/CRT-169-1002/
All I can think is to maybe prevent the fuel from foaming in the tank maybe?
81 KZ1000 LTD
Griffin GA
  • Boostable
24 Dec 2011 16:14
#494553
None what so ever...
~Jack
  • Dave Sloan
  • Dave Sloan's Avatar
27 Dec 2011 03:27
#494799
I think the check valve is just so that he tank can be removed without petrol running all over the place. I have just machined up a shouldered fitting with a washer and nut as I did not want to wreck the paint with welding
Z650B2 - Injected
  • jydog
27 Dec 2011 09:22
#494824
Dave Sloan wrote: I think the check valve is just so that he tank can be removed without petrol running all over the place. I have just machined up a shouldered fitting with a washer and nut as I did not want to wreck the paint with welding
Where did you mount your return and your pump? Any pictures?
81 KZ1000 LTD
Griffin GA
  • jydog
14 Jan 2012 08:50
#498028
Do you have any pictures of how you did this or where you mounted it? Thanks
81 KZ1000 LTD
Griffin GA
  • steell
  • steell's Avatar
14 Jan 2012 12:51 - 14 Jan 2012 13:23
#498051
Dennis Kirk (and others I'm sure) sell quick disconnect inline fittings with check valves,
Just noticed the price on the new version of MicroSquirt has been reduced to $339
Last edit: 14 Jan 2012 13:23 by steell.
  • jydog
14 Jan 2012 15:00
#498067
Yeah, I sold my megasquirt and bought one of the new microsquirt's. Hard to beat that price. Im going to see If I can get it running on fuel only. Made some headway today and installed some ford mustang 5.0 injectors in my gpz1100 tb. They are high impedance which are needed for the microsquirt.
81 KZ1000 LTD
Griffin GA
  • jydog
15 Jan 2012 12:46
#498155
What size fuel line should I be using? 1/4 or 5/16?
81 KZ1000 LTD
Griffin GA
  • Boostable
15 Jan 2012 18:57
#498203
Im using 5/16.... I think 1/4 ID would be fine, but why risk it. :)
~Jack
  • steell
  • steell's Avatar
15 Jan 2012 18:59
#498204
Using the theory of "Too much is not enough", I'd go with the 5/16" line :)
  • jydog
16 Jan 2012 17:02
#498344
Making progress...
81 KZ1000 LTD
Griffin GA
