Megasquirt / Microsquirt a KZ
  • jydog
  • jydog's Avatar Topic Author
Re: Megasquirt / Microsquirt a KZ
08 Sep 2011 13:00
#475133
531blackbanshee wrote: of course.
that is the only way we can build some of these contraptions,and not have to hear everyones opinion of how freakin hairbrained and crazy our ideas are :woohoo: :laugh: :cheer:
Thank, goodness for these screwed up guys or my bike would still be a pile of parts.
81 KZ1000 LTD
Griffin GA
  • ratvespa
  • ratvespa's Avatar
27 Sep 2011 00:18 - 27 Sep 2011 00:19
#479851
Nice too see others are doing KZ MS installs. I finally got sick of my 82 GPz1100 EFI that was about as smart as a atari 2600 that had a waffle jammed where the cartridge would go. I got the MS built, pretty much all the efi hardware (fuel pumps, pressure reg, and sensors) are there. I did end up modifying the stock TB set up to accept more modern injectors.
I used a set of GSXR600 injectors, flow rate should be pretty close. I had some "V" pieces cut via my neighbors shop's waterjet. drilled and tapped some holes, the machined my own bridge piece to connect the 2 since the gpz TB's were a bit wider. Just though I would share. Ill post when I get it up and running.
I got the plugs for the gsxr injectors from dynojet. I no longer run the stock pressure regulator since I only have a single fuel inlet, switched to a aeromotive bypass style.
Last edit: 27 Sep 2011 00:19 by ratvespa.
  • jydog
27 Sep 2011 06:02 - 27 Sep 2011 06:05
#479893
No eBay APP ID and/or Cert ID defined in Kunena configurationHey ratvespa, glad to see another megasquirted kz. That is some creative engineering you have going on there. What aeromotive regulator are you using? That is what I am trying to figure out right now. Some people are using ebay regulators:
motors.shop.ebay.com/i.html?_trkparms=65...0.m245&_sop=15&_sc=1
some MSD:
cgi.ebay.com/ebaymotors/MSD-2222-Fuel-Pr...&hash=item588fc1aca2
and some SARD:
Im a little confused on which one to go with. I might just pick the smallest. That looks like
the SARD but I want to be able to rebuild and replace parts which is where an aeromotive whould be nice.
81 KZ1000 LTD
Griffin GA
Last edit: 27 Sep 2011 06:05 by jydog.
  • ratvespa
  • ratvespa's Avatar
27 Sep 2011 10:00
#479910
I am using this one
its a little bulky, but it high quality. also expensive..I would not be running it if I didn't get it for free!
I used to have it mounted to the top of the starter cover...not sure if I can get it to fit there since I have to run all 3 ports on it now since I changed my fuel rail
  • jus1975
  • jus1975's Avatar
  • www.tripleaperformance.com
28 Sep 2011 00:51
#480130
Which fuel pump are you guys using. I didnt want anything crazy loud. I was thinking of the MPS fuel pump
  • MFolks
  • MFolks's Avatar
28 Sep 2011 01:20
#480134
  • jydog
28 Sep 2011 05:51 - 28 Sep 2011 06:13
#480152
I plan on using a Walbro GSL393 as recommended on 750turbo.com
www.750turbo.com/power.htm
The injectors I plan on using are off a 85-95 volvo 32lb
81 KZ1000 LTD
Griffin GA
Last edit: 28 Sep 2011 06:13 by jydog.
  • ratvespa
  • ratvespa's Avatar
28 Sep 2011 12:03
#480205
jus1975 wrote: Which fuel pump are you guys using. I didnt want anything crazy loud. I was thinking of the MPS fuel pump
stock pump that came with my gpz1100
  • Boostable
  • Boostable's Avatar
28 Oct 2011 23:58
#485855
Hows it going guys... any updates on the EFI... Im considering it..
~Jack
1982 KZ1000 J2 ~ Project (Street Fighter - Project Section)
1976 KZ900 - Daily Rider
  • jydog
29 Oct 2011 01:26
#485861
Thats still the plan. I have almost all of the parts. Im still putting the bike togther and swaping parts. I'll update this thread as soon as I get the rest of the bike togther. I hope to have it complete by next summer.
81 KZ1000 LTD
Griffin GA
  • Boostable
29 Oct 2011 10:27
#485880
Have you guys found any reference to what throttle bodies are roughly the same width and fitment at the KZ intakes?
~Jack
  • jydog
30 Oct 2011 10:56 - 30 Oct 2011 10:57
#486051
Boostable wrote: Have you guys found any reference to what throttle bodies are roughly the same width and fitment at the KZ intakes?
Im going with the 83-84 GPZ1100 throttle bodies. Bolt up and is compatiable with the gpz750 turbo boost plenum I plan on using.
Check this out! the new 3.0 microsquirt ecm module is out from diyautotune. This looks like the way to go
www.diyautotune.com/catalog/microsquirt-...nt-system-p-131.html
81 KZ1000 LTD
Griffin GA
Last edit: 30 Oct 2011 10:57 by jydog.
