Megasquirt / Microsquirt a KZ
  • Boostable
  • Boostable's Avatar
Re: Megasquirt / Microsquirt a KZ
02 Nov 2011 22:38
#486754
OK guys straighten me out here! Instead of using a toothed wheel, why would we not use an electronic crank trigger like the Pro Trigger from Dyna?
What am I missing?
~Jack
1982 KZ1000 J2 ~ Project (Street Fighter - Project Section)
1976 KZ900 - Daily Rider
  • ratvespa
  • ratvespa's Avatar
03 Nov 2011 09:53
#486802
bootstable,
for now I am just going fuel only, MS 2.2 thats been flashed so it has the extras (mostly just wanted the larger fuel tables.
pretty much everything in the bike is stock GPz (kz1100b2) efi, except for the injectors, they were from a mid 2000's gsxr600, I had to make some parts to make them work in my stock TB's. fuel pump is stock, fuel pressure regulator is an aeromotive one (check my post, I think I posted a pic of it in this thread)
I don't have a build of it, just kind of doing it as I find time.
the wiring is pretty much all stock, MS is going to sit where the stock computer sat. the only wires I had to add were injector wires, since the stock harness had the injectors hot all the time, and they all fired at the some time. I went with 2 banks with the MS. if anyone is doing 100b2 I can scan my ghetto wiring diagram I scribbled on some paper.
  • ratvespa
  • ratvespa's Avatar
03 Nov 2011 09:54
#486803
Boostable wrote: OK guys straighten me out here! Instead of using a toothed wheel, why would we not use an electronic crank trigger like the Pro Trigger from Dyna?
What am I missing?
as for the trigger I am just using the tach output on the dyna2000. it should be a clean enough tach output for the MS. if I was controlling spark I would need a toothed wheel.
  • jydog
  • jydog's Avatar Topic Author
03 Nov 2011 19:02
#486879
Boostable, Im going to try using the stock pickups with 3 diodes to combine the signal into one.
Ratvespa, more details on your injector setup please.
81 KZ1000 LTD
Griffin GA
  • steell
  • steell's Avatar
03 Nov 2011 21:47 - 03 Nov 2011 21:50
#486901
jydog wrote: Boostable, Im going to try using the stock pickups with 3 diodes to combine the signal into one.
I don't understand why you're doing the extra work to combine the two signals, just trigger off one or the other.
The only time you need a toothed wheel is if you're using MegaSquirt to control ignition.
Last edit: 03 Nov 2011 21:50 by steell.
  • Boostable
03 Nov 2011 22:07
#486905
Thats my confusion. Why do you need to use a toothed wheel in order for MS to control ignition? Based on what im reading, since V2.8 there is an option for dual input, dual output. (Independent Dual Ignition) Thus giving the ability to have input1 trigger both inj1 and output1, and input2 trigger inj2 and output2. Isn't this what we are after?
Advantages or disadvantages versus a wheel?
Thanks guys..
See the snippet below..
1.Independent dual ignition: This would typically be used for a two cylinder motor, but also can be used with a 4 cylinder engine and wasted spark. It uses two independent tach inputs on VRin1 and VRin2 (NOT a wheel input in the sense that there are not many teeth, just one per cylinder). It is intended primarily for 2 cylinder 'odd-fire' engines. Such engines include the Harley-Davidson (45°), MotoGuzzi (90°), Ducati (90°), Suzuki (75°), and Honda (52°) V-twins.
Alternating tach pulses from two crank or cam wheel sensors (which are physically offset with respect to each other) are fed to the two ignition input circuits and they produce two ignition outputs to separate coils. This can be odd or even fire - it doesn't matter because the pairs of input/outputs are independent.
Input 1 triggers one injection channel (INJ1) and one ignition channel (Output 1), the other input (Input 2) triggers the other coil (Output 2) and injector bank (INJ2). Global things like RPM, etc. are computed from the channel 1 input. Since they are independent, the crank degree spacing between them (i.e. delta T between channel one and channel 2) does not matter. So the unit supports odd-fire, and it also injects based on which input (Input 1 fires injector 1, Input 2 fires injector 2).
If you have an even fire engine, then try to make the input sensors 180° apart (i.e. directly opposite). With independent dual inputs and outputs, the odd-fire angle is generally built into the sensor location from the factory to reflect the offset in firing of the two cylinder banks. If this is the case, do NOT set the second output offset (odd angle) under Advanced Ignition menu. Otherwise the offset would be applied twice, which would not be correct.
In this mode you cannot set the 'toothed wheel', 'trigger return', or 'EDIS' options - they won't work. Also, set the ignition ISR time mask, and the percent mask the same as in non-Dual Spark mode.
~Jack
  • jydog
03 Nov 2011 22:07
#486906
You have to program it as a 2cyl to do that dont you?
81 KZ1000 LTD
Griffin GA
  • Boostable
03 Nov 2011 22:26
#486908
I don't think so, or at least I don't see that on the Megasquirt setting sheet.
Here is the page I am getting this from.
www.microsquirt.info/dualspark.htm
Jack
~Jack
  • jydog
03 Nov 2011 22:35
#486910
Boostable wrote: I don't think so, or at least I don't see that on the Megasquirt setting sheet.
Jack
I dont know if this is the problem but in the settings above it says
"The number of teeth on the crank wheel must be the one-half (½) the number of cylinders"
Our bikes have 1 tooth.
81 KZ1000 LTD
Griffin GA
  • Boostable
03 Nov 2011 22:48
#486911
Running a V with a wheel I could see it, but I would think that the dual crank sensor like an MSD or Dyna would basically represent two teeth 180deg out from one another and allow for proper firing of the ignition through MS. Yes, no, maybe?
Unless I come up with an obvious reason why this would not work, I am gonna have to try it!
~Jack
  • ratvespa
  • ratvespa's Avatar
06 Nov 2011 11:27
#487212
check out page 2 of this thread. you can see the junction I made between the 2 rails, and the v blocks I has made to hold them all down. I am lucky enough to have a mill, lathe, and the shop next to me thats a waterjet shop. The fuel connector piece was the hardest to make. I got some 1/2in hex bar stock from mcmaster carr, and made it wider than the stock gsxr piece since my engine is wider. the gsrx600 (I think mid 2000's, they are all about the same) injectors just dropped in, the spacing for the 1,2 and 3,4 was perfect, and everything dropped into my stock 82 kz1100b2 tb's.
  • ratvespa
  • ratvespa's Avatar
10 Nov 2011 01:24
#487839
well that was too damn easy. hooked up everything tonight, set all the constants, built a caculated table based on hp, tq, peaks, injector flow, and CC's and....well it fired up right away, let it idle with the high idle on for less than a min, then switched it off and let it idle on it own...reved it a few times, felt snappy.
just gotta fix one small fuel leak and get it on the dyno at work and get it close, then put in my wideband and let the computer finish the rest.
