Megasquirt / Microsquirt a KZ
- jydog
Re: Megasquirt / Microsquirt a KZ
03 Sep 2011 10:26tachrev wrote: Here is a site I found that has some smaller 36-1 trigger wheels that may fit in the KZ ignition housing.
I haven't used them, I just bookmarked the site when I was researching this myself.
trigger-wheels.com/store/contents/en-uk/d5.html
Thanks for this refrence. After reading a little more I dont think the HEI mod will work since you would need two of them. I was hoping to keep the stock VR sensors and use off the shelf hardware to drive the ignition. The best way seems to use a wheel and hall sensor. Here is the section I was looking at.
www.megamanual.com/ms2/GM_7pinHEI.htm
It would probably work if the bikes reluctor had 4 teeth.
81 KZ1000 LTD
Griffin GA
Griffin GA
- steell
03 Sep 2011 12:35
For programmable ignition controlled by MS2 for up to four coils, see
4-Channel Ignition/Injection Driver Board
, which also allows sequential four cylinder injection.
Lots of add-ons available
- jydog
03 Sep 2011 19:24
Ok Steell, I'll check that out. Looks like this may be the answer to the trigger wheel problem.
www.microsquirt.com/viewtopic.php?f=89&t=23815&p=151436#p151435
Collecting parts
Collecting parts
Attachment IMG_2346.jpg not found
81 KZ1000 LTD
Griffin GA
Griffin GA
- steell
04 Sep 2011 01:03
Are you going to install a cam position sensor and do sequential injection?
- jydog
04 Sep 2011 09:17
I dont have sequential injection planned yet. Im going to start simple and work my way out. Maybe 2 banks? I might just skip the spark control and just get the fuel done first. Do you know if you can drive the MSII off a tach signal to begin with?
81 KZ1000 LTD
Griffin GA
Griffin GA
- steell
04 Sep 2011 12:21
Yep, a tach signal will work for batch injection.
- jydog
05 Sep 2011 12:31 - 05 Sep 2011 12:38
Im going to use this circuit to combine the coils to trigger the megasquirt since I have 2 VR pickups and two coils running wasted spark. This is for a fuel only setup. Later I will do the ignition. The other way to do this is to is to tell MSII that your engine is a 2 cylinder.
Found the info here
www.msextra.com/forums/viewtopic.php?f=71&t=7499
and here
www.autosportlabs.net/MJLJ_V4_vehicle_in...ltage_kickback_pulse
Thinking about grabbing some 30lb injectors off a turbo SAAB or Volvo. I hear they can be made to fit the gpz throttle bodies and are good for up to 200hp.
Changed my code on the MSII to ms2extra 3.1.0 and using Tunerstudio MS lite 1.14 and changed user level to fuel only to simplify things.
Found the info here
and here
81 KZ1000 LTD
Griffin GA
Griffin GA
Last edit: 05 Sep 2011 12:38 by jydog.
- Dave Sloan
06 Sep 2011 05:20
ignition on a bike is difficult, I ran a missing toothed wheel and had bad starting, I believe it has to do with the crank not turning at a constant speed while turning the motor on the starter.
I am running fuel only at the moment using a dyna s for ignition.
I have the components and have made up an aluminium timing wheel that will hold magnets, this is Arrtu's design and it uses the same timing plate to give both sensor inputs by running one magnet reversed in the plate. Arrtu has run this setup in a few 4cly bikes and it works flawlessly. Have a look through the info below.
oldskoolperformance.com/forum/viewtopic.php?f=6&t=1664
www.amh-sivut.net/mopo/turbo/
Z650B2 - Injected
- jydog
06 Sep 2011 07:43 - 06 Sep 2011 07:54
Thanks for the info Dave. Where did you get the stuff for Arrtu's setup? I am really hoping to figure out a way to use the factory VR pickups since they work currently and reliably. Like using the tach circuit to combine the two signals into one. Do you know if this has been done before? Maybe passing the signal to a factory module HEI or the Bosh unit that can run COP and be controlled by the Megasquirt ecu.
Eventually I want to transfer everything to this:
www.diyautotune.com/catalog/microsquirt-module-v22-p-381.html
81 KZ1000 LTD
Griffin GA
Griffin GA
Last edit: 06 Sep 2011 07:54 by jydog.
- steell
06 Sep 2011 20:34Dave Sloan wrote: ignition on a bike is difficult, I ran a missing toothed wheel and had bad starting, I believe it has to do with the crank not turning at a constant speed while turning the motor on the starter.
Ah! The ubiquitous Mr Fluffy! I met him on the 750turbo board and have run into him on numerous sites since. He's cool
Got a machine shop in his garage also.
- Dave Sloan
08 Sep 2011 06:01
Haven't all the screwed up guys got a machine shop in the garage :laugh:
:sick:
:woohoo: :silly: :side:
Z650B2 - Injected
08 Sep 2011 12:33
of course.
that is the only way we can build some of these contraptions,and not have to hear everyones opinion of how freakin hairbrained and crazy our ideas are :woohoo: :laugh:
