1980 750H bare bones for mattylight
- loudhvx
Re: 1980 750H bare bones for mattylight
20 May 2012 12:44 - 13 Jan 2019 13:58
1977 KZ650 C1 for JohnnyC
EDIT 1/13/2019:
Mattylight Barebones Bare Bones
1977 Kawasaki Kz650C1 with aftermarket ignition switch for JohnnyC
Kz650C Kz650 C1 Kz 650 C 650C1 650C
EDIT 1/13/2019:
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 13 Jan 2019 13:58 by loudhvx.
- loudhvx
07 Oct 2012 03:16 - 13 Jan 2019 13:59
1982 KZ750 H3 for Gregg.
EDIT 1/13/2019:
1982 Kawasaki Kz750H3 for Gregg
Kz750H Kz750 H3 Kz 750 H 750H3 750H
EDIT 1/13/2019:
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 13 Jan 2019 13:59 by loudhvx.
The following user(s) said Thank You: 82bobber750h2
- 82bobber750h2
07 Oct 2012 10:25
thanks so much loudhvx wasent able to find that anywhere
- loudhvx
19 Dec 2012 16:19 - 13 Jan 2019 14:01
1976 KZ750 B1 twin for Jradofarms.
EDIT 1/13/2019:
1976 Kawasaki Kz750B1 twin with aftermarket ignition switch for Jradofarms
Kz750B Kz750 B1 Kz 750 B 750B1 750B
EDIT 1/13/2019:
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 13 Jan 2019 14:01 by loudhvx.
The following user(s) said Thank You: Jradofarms
- loudhvx
03 Jan 2013 15:01 - 13 Jan 2019 14:03
1984 KZ550F2 Ltd, (based on 1983 F1 wiring), for kvtheninja
EDIT 1/13/2019:
1984 Kawasaki Kz550F2 Ltd for Kvtheninja
Kz550F Kz550 F2 Kz 550 F 550F2 550F
EDIT 1/13/2019:
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 13 Jan 2019 14:03 by loudhvx.
The following user(s) said Thank You: kvtheninja
- kvtheninja
03 Jan 2013 15:38
Thanks for the help. I'm going to try to get the new wiring done this weekend.
- NickMac
08 Jan 2013 18:41
Loudhvx
I just wanted to thank you for all the posting you have done on this topic.. This has helped immensely with my build.
I have a 77 kz650b and am wondering if the 77 kz650c diagram you posted a few times is applicable to my bike?
Thanks,
Nick
Thanks,
Nick
- loudhvx
08 Jan 2013 19:39
Thanks Nick, and yes the 77 KZ650B basic wiring should be the same as the 77 KZ650C.
Later KZ650's used very different charging systems.
The way to know if your 650 engine is in fact a 1977 version, is to look on the alternator cover. In the middle of the face of the cover, there should be 3 philips-head screws in a triangle pattern. Later models did not have the screws.
1981 KZ550 D1 gpz.
Other links.
Other links.
- NickMac
09 Jan 2013 12:51
I'll take a look at that when my bike gets back from the shop.
Again thanks!
Again thanks!
- Hollywoodmx
06 Mar 2013 00:07
Hi loudhvx,
Could you put together a diagram for a simplification diagram for a 77 kz1000 with a dyna ignition, battery and a fuel pump (power and ground) for me please?
Thanks!
Thanks!
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- loudhvx
06 Mar 2013 20:41
Sure, give me a day or so.
1981 KZ550 D1 gpz.
Other links.
Other links.
- loudhvx
09 Mar 2013 01:40 - 13 Jan 2019 14:04
1977 KZ1000 with fuel pump for Hollywoodmx
EDIT 1/13/2019:
1977 Kawasaki Kz1000 with Dyna S for Hollywoodmx
Kz 1000
EDIT 1/13/2019:
Kz 1000
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 13 Jan 2019 14:04 by loudhvx.
