1980 750H bare bones for mattylight
- loudhvx
Re: 1980 750H bare bones for mattylight
18 Jun 2013 06:50 - 14 Jan 2019 18:24
1982 Kawasaki Kz1100D1 Spectre for Bbydylanm
EDIT 1/14/2019:
Mattylight Barebones Bare Bones
1982 Kawasaki Kz1100D1 for Bbydylanm
Kz1100D Kz1100 D1 Kz 1100 D 1100D1 1100D
EDIT 1/14/2019:
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 14 Jan 2019 18:24 by loudhvx.
- kz1100warrior
03 Jul 2013 10:19
Hi Loudhvx.
Please can you assist me. The brown wire from the regulator, this wire powers the lights etc correct. I am copying your drawing for Johns kz1000.i have a 4 switch ignition. 1. Ignition. 2 battery.3 acc.4 starter.
What i need to know, does the brown wire get connected to the power wire from the ignition (coils).
I am stumped here....do you need to connect this wire, or can you leave it off. I have everything working, except this brown wire. Please could you draw me a basic diagram for this brown wire going from regulator to key ignition and lights, tail. headlight etc.
Thank you kindly.
Thank you kindly.
- loudhvx
03 Jul 2013 13:08 - 03 Jul 2013 13:16
The brown wire to the regulator is power TO the regulator. It is what the regulator uses to know what voltage the battery is at. Anytime the ignition switch is on, that wire to the regulator must have 12v on it. It should not be inline with any other switch except the main ignition switch.
Be aware, though, that the brown wire also feeds power to many other things on a KZ. It is the switched 12v wire. It has power whenever the ignition key switch is turned on. (Some KZ's may have more than one brown wire.)
In the simplified schematics, that brown wire is tied to the switched 12v line which feeds the entire bike, including the coils and lights and starter solenoid. So even though that wire is connected to many other things, it does not affect, nor is it affected by, those other things. It is simply getting its power from the same place those other things get their power.
And no, leaving it unconnected from the regulator would be really bad for the electrical system.
The 1100 schematic, above your post, shows how it is typically wired on most of the 1000/1100 bikes.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 03 Jul 2013 13:16 by loudhvx.
- loudhvx
09 Aug 2013 19:19 - 14 Jan 2019 18:25
1977 KZ650B1 for NickMac.
Relay mod.
Dyna S.
EDIT 1/14/2019:
1977 Kawasaki Kz650B1 for NickMac
Kz650B Kz650 B1 Kz 650 B 650B1 650B
Relay mod.
Dyna S.
EDIT 1/14/2019:
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 14 Jan 2019 18:25 by loudhvx.
- Beaner242
13 Sep 2013 14:45
please! 82 kz1000 ltd. i will be running headlight, taillight, blinker, starter, stock ignition. thanks very much.
1982 KZ1000K LTD Chopper
- loudhvx
13 Sep 2013 15:26
Do you have a 1982 Kz1000K2 diagram you can upload to the filebase? I don't have one. There is a 1981 K1 diagram, but I'm not sure if it's the same. Also, I'm not sure about the working of the self-canceling turn signal unit. If you are keeping that, I'll need more details on how it works. If you are eliminating it, and just using a manual turn signal switch, then it should be simple.
1981 KZ550 D1 gpz.
Other links.
Other links.
- Beaner242
13 Sep 2013 23:19
I have a manual I got off here some where but the writing is so small I can't read some of it. I am eliminating everything I can like the self cancaler
- Motor Head
13 Sep 2013 23:31K1, and K2 should be the same for electrical.loudhvx wrote: Do you have a 1982 Kz1000K2 diagram you can upload to the filebase? I don't have one. There is a 1981 K1 diagram, but I'm not sure if it's the same. Also, I'm not sure about the working of the self-canceling turn signal unit. If you are keeping that, I'll need more details on how it works. If you are eliminating it, and just using a manual turn signal switch, then it should be simple.
- loudhvx
14 Sep 2013 14:29 - 14 Jan 2019 18:28
Thanks D.
1982 KZ1000K2 Ltd. for Beaner242 based on 1981 KZ1000K1 Ltd.
EDIT 1/14/2019:
1982 Kawasaki Kz1000K2 for Beaner242
Kz1000K Kz1000 K2 Kz 1000 K 1000K2 1000K
EDIT 1/14/2019:
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 14 Jan 2019 18:28 by loudhvx.
- Beaner242
16 Sep 2013 22:43
Thanks so much
- loudhvx
24 Oct 2013 12:18 - 14 Jan 2019 18:30
Kawasaki KZ900 points, with and without battery.
For fastestz1.
Batteryless version requires reg/rec sense line tied directly to reg/rec output, and also requires lights to be off when starting, so requires on/off switch for lights.
EDIT 1/14/2019:
Kawasaki Kz900 with and without battery for FastestZ1
Kz 900
For fastestz1.
EDIT 1/14/2019:
Kz 900
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 14 Jan 2019 18:30 by loudhvx.
- Beaner242
24 Oct 2013 12:24
what program do you use to draw these?
