1980 750H bare bones for mattylight
  • NickMac
  • NickMac's Avatar
Re: 1980 750H bare bones for mattylight
09 Jan 2013 12:51
#566537
I'll take a look at that when my bike gets back from the shop.
Again thanks!
  • Hollywoodmx
  • Hollywoodmx's Avatar
06 Mar 2013 00:07
#575562
Hi loudhvx,
Could you put together a diagram for a simplification diagram for a 77 kz1000 with a dyna ignition, battery and a fuel pump (power and ground) for me please?
Thanks!
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • loudhvx
  • loudhvx's Avatar Topic Author
06 Mar 2013 20:41
#575712
Sure, give me a day or so.
  • loudhvx
09 Mar 2013 01:40 - 13 Jan 2019 14:04
#576075
1977 KZ1000 with fuel pump for Hollywoodmx
EDIT 1/13/2019:
Mattylight Barebones Bare Bones
1977 Kawasaki Kz1000 with Dyna S for Hollywoodmx
Kz 1000
Last edit: 13 Jan 2019 14:04 by loudhvx.
  • Hollywoodmx
09 Mar 2013 03:08
#576088
You're the best man. Greatly appreciated.Thanks!!
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • SometimeLost
  • SometimeLost's Avatar
23 Mar 2013 18:40
#578357
New member need help please.
I have a Kz250DE engine 81' and i think most if not all of the wiring harness and controls.
My question is i plan on using the engine in a small 1 man dune buggy i am fabricating, and would like to know exactly the bare bones min. i need to start and run this engine. And how to wire it if possible. I am ok rebuilding carb and engine, but as far as electrical this will be new to me, only experience i have is with small engine, mostly recoil 6hp types.
So any advice, help would be much appreciated.
I plan on using a battery, and kill switch if possible.
  • loudhvx
23 Mar 2013 18:48
#578360
We don't have that wiring diagram in the filebase for a 1981 KZ250D2 (CSR).
Do you have one I can work from?
  • SometimeLost
23 Mar 2013 19:00
#578365
ccording to this site this model.
zedder.com/Info/81%20KZ250-D2%20CSR.htm
I got couple pics is about all.
Attachment 20130323_1407041.jpg not found
Attachment 20130323_1407241.jpg not found
Attachment 20130323_1407501.jpg not found
  • loudhvx
24 Mar 2013 14:58 - 13 Jan 2019 14:07
#578538
This one is based on a German Kz250 C2/G2 single.
1981 KZ250 D2 single for SometimeLost
EDIT 1/13/2019:
1981 Kawasaki Kz250D2 single for SometimeLost
Kz250D Kz250 D2 Kz 250 D 250D2 250D
Last edit: 13 Jan 2019 14:07 by loudhvx.
  • loudhvx
31 Mar 2013 03:13 - 13 Jan 2019 14:09
#579749
1978 KZ750B3 twin for Larson
EDIT 1/13/2019:
1978 Kawasaki Kz750B3 twin for Larson
Kz750B Kz750 B3 Kz 750 B 750B3 750B
Last edit: 13 Jan 2019 14:09 by loudhvx.
The following user(s) said Thank You: Larson
  • Redhedgoon
  • Redhedgoon's Avatar
04 Apr 2013 02:15
#580497
this thread has a lot of information! can the 1978 kz1000 wiring diagram be used for a 1994 kz1000 police special? im not running anything fancy other than headlight, brake light, license plate light, and ignition. just wondering if a diagram that is already on here can be used. just looking for a basic diagram that shows where relays, if needed, fuses , grounds and terminals should be tied and ended. thanks!!!
  • loudhvx
04 Apr 2013 13:38
#580543
Actually, I can't say what a 94 KZP is wired like. I assume it has electronic ignition, so that would be different from the 77-78 1000. I would need a diagram to work from to check the charging system etc. If you have a link, that would be great.
