1980 750H bare bones for mattylight
  • loudhvx
  • loudhvx's Avatar Topic Author
Re: 1980 750H bare bones for mattylight
24 Oct 2013 12:33
#611035
Just plain old Microsoft MSpaint. It comes on every version of Windows so it's convenient for me. I can't install programs at work, but it's already there. I'm sure any raster drawing program should be able to edit it.
The following user(s) said Thank You: Beaner242
  • loudhvx
27 Nov 2013 13:04 - 14 Jan 2019 18:32
#614234
1981 Kawasaki KZ650D4 for Ehde.
with automotive ignition switch.
EDIT 1/14/2019:
Mattylight Barebones Bare Bones
1981 Kawasaki Kz650D4 with aftermarket ignition switch for Ehde
Kz650D Kz650 D4 Kz 650 D 650D4 650D
Last edit: 14 Jan 2019 18:32 by loudhvx.
  • ehde
  • ehde's Avatar
30 Nov 2013 05:59
#614440
Awesome! I'm so grateful!
One question though. My ignition switch only have three positions. Off-ign-start, I suppose this will make a differene?
Thanks!
  • loudhvx
04 Dec 2013 11:01
#614767
been really busy. I'll redo it when I get some time.
  • loudhvx
06 Dec 2013 03:25 - 14 Jan 2019 18:34
#614894
1981 Kawasaki KZ650D4 SR for Ehde.
Redone using relay instead of common car ignition switch toturnoff lights while starting.
EDIT 1/14/2019:
1981 Kawasaki Kz650D4 with automatic headlight dimmer for Ehde
Last edit: 14 Jan 2019 18:34 by loudhvx.
  • loudhvx
21 Jan 2014 23:39 - 14 Jan 2019 18:35
#619583
1981 Kawasaki KZ550C2 Ltd. for Calebjkd
EDIT 1/14/2019:
1981 Kawasaki Kz550C2 for Calebjkd
Kz550C Kz550 C2 Kz 550 C 550C2 550C
Last edit: 14 Jan 2019 18:35 by loudhvx.
The following user(s) said Thank You: Calebjkd
  • Calebjkd
  • Calebjkd's Avatar
22 Jan 2014 00:08
#619585
Im a little confused, may just be inexperience.
Between the Starter button and the starter solenoid where the wire goes from blk (@ button) to red/yel (@ solenoid), is this a ground wire?
Or is it to complete the circuit?
'81 Kawasaki kz550 ltd
'71 Yamaha xs650
  • Calebjkd
  • Calebjkd's Avatar
22 Jan 2014 00:49
#619586
Nevermind, figured it out!
Thanks for the time and effort loudvhx.
My bike thanks you too!!
'71 Yamaha xs650
  • loudhvx
22 Jan 2014 08:04
#619609
No prob. THe factory originally had the red/yel as ground, and black as hot on the coil (and black as hot on the start button), but the two small wires on the solenoid can be interchanged. I thought red/yel would make more sense as hot, even though the start button uses black. Feel free to wire it whichever way makes more sense to you. I think the factory flubbed it, so either way it will still have some confusion.
  • Lazyman06
  • Lazyman06's Avatar
26 Jan 2014 08:09
#620094
I have one for you if you don't mind drawing one up for me. 79' KZ1000 MKII bare bones with the regulator/rectifier combo, aftermarket ignition panel, no turn signals, no speedo/tach, no handlebar switches.
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
  • loudhvx
27 Jan 2014 00:21
#620191
Lazyman06 wrote: I have one for you if you don't mind drawing one up for me. 79' KZ1000 MKII bare bones with the regulator/rectifier combo, aftermarket ignition panel, no turn signals, no speedo/tach, no handlebar switches.
Can you describe the ignition switch in more detail?
How will you control high/low beam?
  • Lazyman06
27 Jan 2014 06:03
#620212
something like this. Just a lgnition panla for like a drag car
www.google.com/shopping/product/2968344550277015213 ?
q=ignition+panel&rlz=1C1CHMO_enUS566US567&es_sm=93&biw=1097&bih=541&dpr=1.75&ei=O2bmUojSBKvfsASL7YDwCw&ved=0COYCEKYrMA0
The high\low beam: I was wanting to run like just the high beam, but if I have to use a switch than I'll work it in somehow
