87 KZ305LTD can't stay alive
- punisher11b
Re: 87 KZ305LTD can't stay alive
15 Mar 2016 19:15
cs.kawasakiclub.net/manual_download.php?id=15
I'm not sure what happened to the kz 750 forum but this seems like the best place to get the free manual now.
- good luck
- JackImpact
- punisher11b
15 Mar 2016 20:28
This is the best I have at the moment. I' currently have it all assembled with black side covers but still have to hunt some electrical gremlins before it will run. Wrecked it about 8 years ago, have spent that time putting it back together peice by peice.
Attachment not found
- good luck
- JackImpact
16 Mar 2016 06:04punisher11b wrote: This is the best I have at the moment. I' currently have it all assembled with black side covers but still have to hunt some electrical gremlins before it will run. Wrecked it about 8 years ago, have spent that time putting it back together peice by peice.
Is that the stock carbs on yours?
- punisher11b
16 Mar 2016 10:29
Yep, still have the original carbs on it. I like them, but that's only because they had been taken really well care of when I got them. I have the same mikuni carb you have on my 440, way easier to fix and work on. Have you had any luck with getting it running right?
- good luck
- JackImpact
16 Mar 2016 10:34
Its running rich, so needs some more fooling around.
- punisher11b
16 Mar 2016 10:45 - 16 Mar 2016 10:47
Yeah, that's pretty common for those mikuni conversions. Does it ride sluggish or just idle rich? If its just at idle i would open those air screws to three turns out on both, then check idle. If it idles great with the air screws open 3 turns then you know your on the rigjt track. Test ride it and check performace. If it starts acting up riding it, screw the air screws in half a turn and recheck till done. How high up are you in elevation? Just wondering because I had to lower my piolet jet when I moved to 5000ft. Just seen your other post, man that bike looks sweet! :woohoo:
- good luck
Last edit: 16 Mar 2016 10:47 by punisher11b.
- JackImpact
16 Mar 2016 12:01
I am in Ohio. So not very high. If I open the throttle all the way it almost dies. I think its idling rich and running rich.
- punisher11b
16 Mar 2016 12:22 - 16 Mar 2016 12:23
The air screw will affect about the first 50% of the throttle opening in your carb. Unscrewing the air screw three turns from seated and checking is you best bet, however you may need to adjust your needle position or a few other things. Here is a really good article on tuning your carbs if the air screw doesnt help. The carb size and all the jet sizes it mentions may be different from yours but the process is all the same.
www.amckayltd.com/vm34-36.pdf
- good luck
Last edit: 16 Mar 2016 12:23 by punisher11b.
- JackImpact
20 Mar 2016 08:35punisher11b wrote: The air screw will affect about the first 50% of the throttle opening in your carb. Unscrewing the air screw three turns from seated and checking is you best bet, however you may need to adjust your needle position or a few other things. Here is a really good article on tuning your carbs if the air screw doesnt help. The carb size and all the jet sizes it mentions may be different from yours but the process is all the same.
Let it sit for two days. Started it up with choke, was really gassy. Ran for a few minutes then choked itself out.
- punisher11b
20 Mar 2016 08:44
If it did that with the air screws turned all the way out then you will probably need to drop the piolet jets down a size. Will it run without choke? If the piolets are that rich it should start without choke easily! You may need to apply throttle but should still cold start easily.
- good luck
- JackImpact
20 Mar 2016 11:45
They arent all the way out, but they are fairly far out
