Mikuni VM 33 Carbs
- daveo
Re: Mikuni VM 33 Carbs
27 Apr 2017 22:01
None better place besides home...
Sounds like you are there
1982 KZ1100-A2/1170cc sleeper 😀
06 Jun 2017 14:30
The bike finally "leaned out." It had to get pretty hot to do it. I got back home and adjusted the timing and pilot screws. Much better. The bike pulls harder and some of the noise has gone away. I'd rather not go back to the #70's. I may go leaner still. I'll do the cam bearings and readjust.
28 Jun 2017 15:21
The oppressive heat has lifted at least for a few days. Got a few things to get done while I have the chance in the mornings.
28 Jun 2017 17:51
Test ride tomorrow.
30 Jun 2017 06:33
Took a ride up and down the HWY. The main thing I wanted to know is if it would bog on roll on. It doesn't. The ;pilots are less responsive though.
In the old Clymer manual I had that was stolen years ago there was a performance section that showed how to change the cutaway from 2.0 to 1.5. The one I bought in the 90's has it listed on the cover but that section is missing. It involves filing the bottom of the slides but I'm having trouble finding it online. Anyone have a old Z1, Z1a, Z1b Clymer on their shelves? The early Z1's had 2.0 slides and this was a common mod at the time.
As it stands now, it's obvious I need smaller pilots with the larger mains. I'll pick some up on Monday.
02 Jul 2017 17:48
Checked the plugs. I'll pick up #55 pilots tomorrow. Still a little rich. I'm going to add this guy to my thread. Good advice.
- daveo
02 Jul 2017 18:39 - 02 Jul 2017 18:46
No eBay APP ID and/or Cert ID defined in Kunena configurationAnything like this?
Last edit: 02 Jul 2017 18:46 by daveo.
02 Jul 2017 18:56
The one I had was from the 80's.
03 Jul 2017 20:25
I might put them in tomorrow. The bike runs great but I think it could be leaner.
07 Jul 2017 11:53
I think it's running lean midrange and that's when it's burning oil.
- KZB2 650
09 Jul 2017 10:03
Hey Steve don't 2.0 slides had a bigger cut away than the 1.5s so you can file 1.5s to make em 2.0s but not the other way around ??
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
09 Jul 2017 11:40 - 09 Jul 2017 11:51
The way I understand it, you can file .5mm off the bottom and make them 1.5. To make them 2.0 you have to make the cutaway taller.
Last edit: 09 Jul 2017 11:51 by SWest.
The following user(s) said Thank You: KZB2 650
