Stumped! Carbs valves electrical or what?
Re: Stumped! Carbs valves electrical or what?
30 Sep 2015 14:10
#692666
1800 rpm idle? :S
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Sep 2015 14:18
#692668
Must be some radical cams.
  • Dirtyhands
  • Dirtyhands's Avatar Topic Author
30 Sep 2015 14:22
#692670
They are actually Andrews cams but were made before they stamped the ends of the shaft so there was no information to be found on the specs for degreeing them. After measuring lobe centers and duration I was able to find ones that matched the numbers made by Megacams. That's who I called. My cams have been degree'd to the specs of the 471-10 cams on the atta
Attachment Mega_Cycle_Cams-2.jpg not found
ched specs sheet.
1977 KZ650B
KZ750H Motor Installed
gpz750 Intake cams Kz750 Exhaust Cams
VM28SS Mikuni Pumper Carbs
Elecrosport Stator and Regulator Rectifier
Dyna 3ohm coils
Derale Oil Cooler
4into1 delkevic Pipes
Pod Airfilters
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Sep 2015 14:33
#692672
Cool. B)
  • KZB2 650
  • KZB2 650's Avatar
30 Sep 2015 15:05
#692675
I always planned on the 471-70 cams with .380 lift........... yours are defently a step up yet...bad to the bone. :woohoo: Maybe compromise and idle at 1,400 or just over guess it depends on how clean it ldles ?
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • pete greek1
  • pete greek1's Avatar
30 Sep 2015 15:33
#692683
Dirtyhands wrote: They are actually Andrews cams but were made before they stamped the ends of the shaft so there was no information to be found on the specs for degreeing them. After measuring lobe centers and duration I was able to find ones that matched the numbers made by Megacams. That's who I called. My cams have been degree'd to the specs of the 471-10 cams on the atta
ched specs sheet.
Wow, how old ARE, those cams, ? I bought a turbo head with Andrews 9X cams in the 80s that came from Ray Belluci , from Belluci Racing out of Chicago that he used to run low 8s on a KZ 900 or KZ 1000 back then,, & they are marked 9 X on the end of the shaft
Pete
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Sep 2015 15:46
#692685
So how does it run now?
  • pete greek1
30 Sep 2015 16:50
#692703
ched specs sheet.
Pete
www.facebook.com/photo.php?fbid=10201435...1179709345162&type=3
  • Dirtyhands
30 Sep 2015 22:51 - 30 Sep 2015 22:52
#692729
Unfortunately I tore the gasket popping the valve cover off so I had to order a new one. Hopefully it'll be here soon and i'll let you know how it all turned out Steve.
I'm not sure how old the cams are Pete. The bike had the 750 kit put on in 1978 so they may be as old as that. I only assume they are older than when Andrews started stamping their cams. It's possible there's another explanation (like a special order or something)
That Belluci bike looks killer!!!
Zac
1977 KZ650B
Dyna 3ohm coils
Derale Oil Cooler
Pod Airfilters
Last edit: 30 Sep 2015 22:52 by Dirtyhands.
  • Tyrell Corp
  • Tyrell Corp's Avatar
01 Oct 2015 03:03
#692744
... and found out that the preferred lift is more like between .006inch and .007inch (.152mm - .178mm) She also Said these cams also don't like to be idled low (under 1800rpm
Valve clearances slightly different to stock on those.
The high idle is to avoid oil starvation with those race cams, IIRC Megacycle also recommend a synthetic oil too. These cams aren't really for riding around town on,
  • Dirtyhands
01 Oct 2015 09:04
#692823
Megacam was saying that any premium oil that still uses zinc like motul is what you want. She didn't specify synhetic or not. These cams really blast off at 6000rpm and are a ton of fun but I do a lot of city riding and may have to put some milder cams(like GPZ Cams) in one day. I'd just like to see if I can nail down the tuning and have some fun before I decide to part with them or not.
1977 KZ650B
Dyna 3ohm coils
Derale Oil Cooler
Pod Airfilters
  • Dirtyhands
09 Oct 2015 15:19 - 09 Oct 2015 15:31
#693974
got everything back together after readjusting the valves and cleaning carbs ( 100% apart ultra sonic dipped and blown out with air compressor) The bike seems even faster but I'm still having the exact same plug issues. I think I'll try moving the needle position from 3 to 4 but I'm concerned that this will make carbs 1 and 2 way too lean.
1977 KZ650B
Dyna 3ohm coils
Derale Oil Cooler
Pod Airfilters
Last edit: 09 Oct 2015 15:31 by Dirtyhands.
