Stumped! Carbs valves electrical or what?
11 Sep 2015 16:16 #689645 by Dirtyhands
Stumped! Carbs valves electrical or what? was created by Dirtyhands
Hello Again Everyone,
Here's my current situation #4 spark plug is carbon fouling and other 3 range from great to a bit rich looking. I've attached two pictures below. One with a set of B8ES plugs and the other with B7ES
I've been chasing this problem around for a while now but can't seem to nail it and would appreciate any help or pointers I can get. I'll give you all the info now
The Bike is a '76 Kz650 that's been bored up to a 738cc . I have not checked compression but the bike runs powerfully when plugs are fresh. I Recently shimmed the valves and degree'd the cam (it has a .410 lift cam in it)
I'm running VM29 smoothbore Carbs that are currently set up with a 120 main jet and a 20 pilot jet. I had 25 pilots in before but had the same issues. The carbs have been dipped and blown out with an air compressor. I took them off again today and used carb cleaner and the compressor focusing on air jet and other air paths hoping there was just a clog. Everything seems clear but the problem persists. I've tried different setting on the air jet ranging from a 1/4 turn out to 3 turns out on carb with the fouling plug but it doesn't seem to help. The carbs have two two into one pod filters.
I've Pretty much switched out the entire electrical system and have tried swapping plug wires around with no luck. It has Dyna S cdi with dyna 3 ohm coils an electrosport stator and electrosport reg/rect. I've dialed in the cdi with a timing light.
I'm a novice to performance tuning so any help would be greatly appreciated
Zac
1977 KZ650B
KZ750H Motor Installed
gpz750 Intake cams Kz750 Exhaust Cams
VM28SS Mikuni Pumper Carbs
Elecrosport Stator and Regulator Rectifier
Dyna 3ohm coils
Derale Oil Cooler
4into1 delkevic Pipes
Pod Airfilters
11 Sep 2015 16:26 - 11 Sep 2015 16:27 #689648 by Tyler
Replied by Tyler on topic Stumped! Carbs valves electrical or what?
738cc would mean you have a 750 top end. Im not familiar with the 29 smoothies, but Is there a vacuum port our something on the number 2 carb that could cause an air leak? You may have to run a small wire through the passages in the carb, sometimes solvent and air are not enough to cut it. Since the other plugs look ok, I'd concentrate on that number 2 carb. Have you done a carb sync? And did you check your vale clearances while you were degreeing your cams?
"74 Yamaha DT 400 Enduro
Last edit: 11 Sep 2015 16:27 by Tyler.
11 Sep 2015 16:30 #689650 by 650ed
Replied by 650ed on topic Stumped! Carbs valves electrical or what?
There's no such thing as a 1976 KZ650. Maybe you mean it is a 1977 KZ650 that was built in 1976? Ed
11 Sep 2015 16:36 - 11 Sep 2015 16:40 #689651 by Dirtyhands
Replied by Dirtyhands on topic Stumped! Carbs valves electrical or what?
Yes Ed, Built in '76 but I guess it's a 1977 650B It was first registered as a '76 so that's what threw me off
1977 KZ650B
Dyna 3ohm coils
Derale Oil Cooler
Pod Airfilters
Last edit: 11 Sep 2015 16:40 by Dirtyhands.
  • SWest
  • 10 22 2014
11 Sep 2015 18:46 #689667 by SWest
11 Sep 2015 23:46 #689684 by Dirtyhands
I have not . I bench set the float heights to 25mm but have noticed it will drip gas out of the fuel filter when parked . the bike is side stand only and is parked nose up on a pretty good hill so I'm not sure iif this is to be expected or a symptom of high float levels . I have to get the attachment that screws onto the float bowl so I can test them.
1977 KZ650B
Dyna 3ohm coils
Derale Oil Cooler
Pod Airfilters
  • SWest
  • 10 22 2014
12 Sep 2015 04:09 #689703 by SWest
12 Sep 2015 06:41 #689726 by spdygon
Replied by spdygon on topic Stumped! Carbs valves electrical or what?
If u have a good spark at each plug...then it's your carbs.
Need a good cleaning...meaning and most likely take them apart .
I
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • SWest
  • 10 22 2014
12 Sep 2015 08:32 #689743 by SWest
Replied by SWest on topic Stumped! Carbs valves electrical or what?
Could be a combination of things. Oil fouling due to bad valve guide seals causing poor spark, followed by too rich a mixture. If it's burning oil, it will have to be run leaner.
12 Sep 2015 16:53 #689798 by Patton
Replied by Patton on topic Stumped! Carbs valves electrical or what?
Dirtyhands wrote: I have not . I bench set the float heights to 25mm but have noticed it will drip gas out of the fuel filter when parked . the bike is side stand only and is parked nose up on a pretty good hill so I'm not sure iif this is to be expected or a symptom of high float levels . I have to get the attachment that screws onto the float bowl so I can test them.
Can use a conical rubber grommet or section of rubber hose fitted into the drain hole which serves as a connection for the clear tube.
Have never used or needed the "special tool."
Minor gasoline seepage, if it can't be avoided, doesn't affect the clear tube test.
Good Fortune! :)
12 Sep 2015 19:35 - 12 Sep 2015 19:37 #689818 by Dirtyhands
That's a cool trick Patton, Thank you! I'm gonna give it a shot come my next day off. Would an excessively high float level contribute to fowling plugs?
1977 KZ650B
Dyna 3ohm coils
Derale Oil Cooler
Pod Airfilters
Last edit: 12 Sep 2015 19:37 by Dirtyhands.
  • SWest
  • 10 22 2014
12 Sep 2015 19:41 #689819 by SWest
