Stumped! Carbs valves electrical or what?
  • Dirtyhands
  • Dirtyhands's Avatar Topic Author
Re: Stumped! Carbs valves electrical or what?
23 Oct 2015 23:35
#695694
I wanted to ride it a few times to make sure I wasn't jumping the gun but the problem seems fixed! moving the needle positions from 4 to 3 seemed to be the final step in ironing out the tuning. I'm glad I took the long way around on this as I was able to dial in the valves, electrical system and give the carbs a few good cleanings. Thank you again to everyone who helped me with this; this forum is an invaluable resource!
1977 KZ650B
KZ750H Motor Installed
gpz750 Intake cams Kz750 Exhaust Cams
VM28SS Mikuni Pumper Carbs
Elecrosport Stator and Regulator Rectifier
Dyna 3ohm coils
Derale Oil Cooler
4into1 delkevic Pipes
Pod Airfilters
