- Thank you received: 225
Premium Fuel?
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- otakar
I was trying to figure out if there is any documentation as to the mechanism by which napthalene might increase mileage. I would think it would have to be one of three things:
1) It does something to the gas mix to make it burn more completely.
2) The napthalene itself is some kind of energy dense substance that burns and imparts energy.
3) napthalene and gas form a new compound which has a higher energy density.
With it being used for decades, I would have thought chemists would have figured this out by now.
Ahh. Finally a man that reads. Yes your #2 is the one. That is all it is. You are actually burning the Naphthalene. The Gasoline is the solvent and the carrier. BINGO.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- otakar
The reason I did not get into that subject is two fold.Well, I've been waiting for it, but I guess no one's going to ask...
What do you do with the rest of the moth?
:laugh:
:blush:
1)There is not much use for neutered moths.
2) Moths that have balls the size of a Nickel get pretty pissed and you don't want to have anything to do with them once you have gelded them. :blush:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
otakar wrote:
Naphthalene WILL NOT increase octane of modern fuels by more than a fraction of a %. It however is a complex energy dense hydrocarbon. I am supplying you with results which I have achieved, and with the cooperation with Argonne engineers. What you do with this information (or not do) is up to you. All I know is that it saves me about 20% in real $s on fuel costs on my cars. That is all I require to know. I do NOT run it in my bike because fuel cost is not an issue at 40+ mpg. Yes if used in access Naphthalene will burn very dirty if used in over abundance. This over abundance is about 10x or more of what I am using. The old formula when octane of motor fuel was about 40 octane was about 12 balls/Gal of gas. This raised the octane rating by about 50%, to about 60 octane. Xylene and Toluene however will raise octane by quite a bit on even modern fuels. If you read the entire post, that is where this discussion came from. I only answered the comment about "Moth Balls" and how I use them and for what purpose, and how it works for me. If you have not done any real tests your selves and have only opinions
well you know what they say about opinions. I know what I know because of the actual testing which I have personally done. Take it or leave it.
:laugh: :laugh: :laugh: :whistle:
I thought it was ok to offer an opinion...
Peace.
Yes it is that Is why i have so many and such big ones. Because I am the biggest of them all :laugh:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
No harm at all. You can add more than that without harming anything. If you go more than one/Gal of gas there will not be any extra benefit. If you have carburetors and you are not running lean there will not be any benefit at all.so if i toss two mothballs .the fuel safe type,in cup of gas and disolve em,and toss it in my kz tank when full,is there a risk to my bike?
simple yes or no maybe?
cause it is either yes or no ,unless i am reading this wrong...thanks..
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bountyhunter
- Thank you received: 337
Does this mean if you run carbs that are set up to proper mix range the mothball thing doesn't have any effect?If you have carburetors and you are not running lean there will not be any benefit at all.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- otakar
The ones I get are these. Just make sure it states "Naphthalene" as the ingredient. Enzos makes both, but the box looks different. Also dissolve them in either Toluene or Xylene. The formula I listed in the first Moth ball post id wrote works the best, with Lucas and either Xylene or Toluene. Which ever is easier for you to get. That will usually be Xylene.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bountyhunter
- otakar
the carburetors and the intake boots. If you have a sealer(liner) in the tank it will damage that. If you add too much Acetone to your fuel it will induce severe detonation.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- blue75kz900
Does it just take too long or it just doesn't disolve?
Thanks.
Blue 1975 KZ900
Gold 1970 Chevy Nova 427...Bike killer
