- Thank you received: 3
Premium Fuel?
- 9am53
- homebrew, and some bbq
[quote/] I have never heard of the electrical watt for HP only James Watt. Just curious as I am no science guy[/quote]
In europe kW is often used in lieu of hp
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Thank you received: 2237
Using higher octane fuel than the engine is designed for or needs is a waste of money and can actually DECREASE power. A couple of guys over at zrxoa have done dyno runs with different octanes of fuel in the same bike to confirm this.
But to the side issue, If I put mothballs in the tank of my truck, will I kill moths as I drive? If it would kill mosquitoes too, I'd do it for sure!
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- trianglelaguna
- Thank you received: 235
simple yes or no maybe?
cause it is either yes or no ,unless i am reading this wrong...thanks..
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Naphthalene WILL NOT increase octane of modern fuels by more than a fraction of a %. It however is a complex energy dense hydrocarbon. I am supplying you with results which I have achieved, and with the cooperation with Argonne engineers. What you do with this information (or not do) is up to you. All I know is that it saves me about 20% in real $s on fuel costs on my cars. That is all I require to know. I do NOT run it in my bike because fuel cost is not an issue at 40+ mpg. Yes if used in access Naphthalene will burn very dirty if used in over abundance. This over abundance is about 10x or more of what I am using. The old formula when octane of motor fuel was about 40 octane was about 12 balls/Gal of gas. This raised the octane rating by about 50%, to about 60 octane. Xylene and Toluene however will raise octane by quite a bit on even modern fuels. If you read the entire post, that is where this discussion came from. I only answered the comment about "Moth Balls" and how I use them and for what purpose, and how it works for me. If you have not done any real tests your selves and have only opinions
well you know what they say about opinions. I know what I know because of the actual testing which I have personally done. Take it or leave it.
:laugh: :laugh: :laugh: :whistle:
I thought it was ok to offer an opinion...
Peace.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- loudhvx
- Thank you received: 1616
What do you do with the rest of the moth?
:laugh:
:blush:
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- bountyhunter
- Thank you received: 337
You release all the neutered moths back into the wild which will help control the moth population and help them improve the decor of their nests....Well, I've been waiting for it, but I guess no one's going to ask...
:laugh:
:blush:
- bountyhunter
1) It does something to the gas mix to make it burn more completely.
2) The napthalene itself is some kind of energy dense substance that burns and imparts energy.
3) napthalene and gas form a new compound which has a higher energy density.
With it being used for decades, I would have thought chemists would have figured this out by now.
- Thank you received: 2098
