Carb Stand from old carb holders.
- loudhvx
Re: Carb Stand from old carb holders.
17 Nov 2015 07:46 - 17 Nov 2015 07:49
Well in the dozens of syncs I've done, you can alter the sync by 5 to 10 mm of mercury just by wiggling the carbs around a little on the engine. If it goes to over 10, I like to re-sync, though they say up to 20mm is ok. But I notice a difference in the running by then. Installing the carbs, especially with an airbox, is going to require a sync check for sure.
I didn't mean a bench sync was totally useless on a good engine. I meant the bench sync was not a good means of getting a final sync. A bench sync is always a good starting point. I just think a final sync should be done on the bike (assuming compression and valves are all set and good), and might as well since you'll have to set it up to check anyway (thus saving the extra time you would use to precisely sync the carbs on the bench).
If one cylinder is unable to flow as much air as the other cylinders (a low compression reading will show this), for whatever reason, it's vac reading will be lower than the others when all throttles are at the exact same opening. That cylinder will do less work since it gets less air. What's worse is, a vacuum sync would have you close down that one throttle to get the vacuum reading back up to where the other cylinders are at. So you have then reduced the airflow to the weak cylinder even more, and thus it will do even less work. This increases the uneveness of the idle.
Using vacuum to sync throttles is based on the assumption that all cylinders are in the same condition (and all carbs and carb holders are in the same condition, meaning not leaking air somewhere).
I suggest that the smoothest sync would be to time the intervals between firing and adjust the throttles so the interval was the same for all cylinders, but I've never tried to do it that way. It wouldn't be too hard with a scope. It would be interesting to see what the vacuum ends up at if done this way.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 17 Nov 2015 07:49 by loudhvx.
The following user(s) said Thank You: floivanus
- car5car
- Banned
17 Nov 2015 18:02Wiggling should not change anything is clamps are tight.loudhvx wrote: you can alter the sync by 5 to 10 mm of mercury just by wiggling the carbs around a little on the engine. If it goes to over 10, I like to re-sync, though they say up to 20mm is ok. But I notice a difference in the running by then. Installing the carbs, especially with an airbox, is going to require a sync check for sure.
Firing interval? What are you talking about? You are going to change firing intervals by adjusting synchronizing? How many beers did you have?
96 Yamaha Royal Star
82 Yamaha Virago 920
17 Nov 2015 18:16
Please keep it civil gentlemen. :whistle:
- floivanus
17 Nov 2015 18:25
Jiggling carbs would cause sync disturbance because of the slop inherent in the design (pivot shaft, arm that goes ro slide, dampening springs in slide, slide adjusters and slide fit in the bore.
Not exactly sure what lou means, but considering he is one of the electrical gurus on here I tend to listen to what he says
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- NakedFun
18 Nov 2015 01:29floivanus wrote: Jiggling carbs would cause sync disturbance because of the slop inherent in the design (pivot shaft, arm that goes ro slide, dampening springs in slide, slide adjusters and slide fit in the bore.
Well I'll just say this, if simply jiggling the carbs sets sync out of whack, I would guess between the engine vibrations and shock emitted from the chassis as the bike moves would never leave the bike in sync....
I would suspect you have some pretty worn (and leaking) cross shafts and linkages.
Anyway, back to the discussion of bench carb stands for maintenance.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- bluej58
18 Nov 2015 03:03
With my old VM 28's all you had to do is look at them cross eyed and they would be out of sync. My 33's have internal linkage and I've had them off a few times, the bike still idles fine. I'm going through them again soon for fine tuning after all the other work has been done. This will be the forth time in 2.5 years.
- NakedFun
18 Nov 2015 04:48Nice! You could always use that one as a grave marker...."Here lies the carb tuner. May they rest in Pieces...."!
Lol
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- spdygon
18 Nov 2015 11:34 - 18 Nov 2015 11:35
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
Last edit: 18 Nov 2015 11:35 by spdygon.
18 Nov 2015 11:44
Sure beats hanging them up with wire. Now that I have new holders I can make one for myself.
- floivanus
18 Nov 2015 14:05 - 18 Nov 2015 14:11NakedFun wrote:floivanus wrote: Jiggling carbs would cause sync disturbance because of the slop inherent in the design (pivot shaft, arm that goes ro slide, dampening springs in slide, slide adjusters and slide fit in the bore.
Cory
And that's the thing, jiggling does make them off kilter a minute amount, if it goes worse than that they need looked at. Ergo what lou was saying, and yes thread hijacking seems rampant. Don't know how this got off course.
For a carb holder I just use a spare gs750 head. Tried selling it, now it's a carb holder. Or IF I'm too lazy for that I use the handle of my outdoor recycling bin
Andrew
Andrew
Last edit: 18 Nov 2015 14:11 by floivanus.
18 Nov 2015 14:18
The thread was going off course a little but back again. I for one don't mind a little dialog in my threads as long as it doesn't become abusive.
