Top-End Redo
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Top-End Redo
07 Oct 2019 08:40
#811986
Are they sending you a new one?
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
Re: Top-End Redo
07 Oct 2019 08:49 - 08 Oct 2019 07:45
#811987
SWest wrote: Are they sending you a new one?
Cometic said my supplier needs to take care of it, and resisted assisting any further on the matter.
So I sent another email to Joe...
:sick:
Update 10/08. Beep-beep-beep, ur-ur-ur, screech~~~uh...pop-boom
MTC says STOP!
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 08 Oct 2019 07:45 by daveo.
  • zippy61
  • zippy61's Avatar
Re: Top-End Redo
07 Oct 2019 10:24
#811996
Think the piston is the same as mine, forgot to say i also have Ape studs and head nuts.
  • daveo
  • Premium Member
  • Premium Member
Re: Top-End Redo
08 Oct 2019 07:25
#812057
Street Fighter LTD wrote:
daveo wrote: Cometic Technical Service today put a halt to using either one of these gaskets. Said to "definitely use set having 74mm + bore opening for certain, and this set must have been improperly stamped when manufactured."
So, thank you again Dave for pointing this out. I prefer to err on the side of caution.
I Hate being right to slow you down , Love it to keep your project bulletproof
Keep up the good work
Oh brother... :ohmy:
Boys and girls, we have a problem here. I would rather ignore it and plunge in, but the respect for getting things right has stopped my progress dead cold.
Fortunately my oil sucking engine is still together, and running better than ever!
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Top-End Redo
08 Oct 2019 07:31
#812059
Just keep a sharp eye on the oil and ride it until snow time
  • daveo
  • Premium Member
  • Premium Member
Re: Top-End Redo
08 Oct 2019 07:46 - 08 Oct 2019 11:48
#812061
Street Fighter LTD wrote: Just keep a sharp eye on the oil and ride it until snow time
:laugh:
I've spent enough time and cash, and am biting at the bit to get this done. Having to wait for re-engineered and manufactured gaskets does not get it for me.
Double-checked the gasket opening relationship to piston diameter. The OEM Kawasaki gaskets easily fit over, but the Cometic don't...except for only one opening of the four. Hmmm.
:whistle:
Last edit: 08 Oct 2019 11:48 by daveo.
  • daveo
  • Premium Member
  • Premium Member
Re: Top-End Redo
09 Oct 2019 17:55
#812145
Apparently MTC got a bad batch and are returning their stock to Cometic, and will send me one of the correct size.
Anyone planning to assemble an engine with 2-pc. 74mm Cometic head gaskets should double check the bore measurements.
Sure am glad I caught this, and thanks again Dave A.
  • daveo
  • Premium Member
  • Premium Member
Re: Top-End Redo
22 Oct 2019 10:09 - 23 Oct 2019 08:35
#812850
Clayed one piston to confirm clearances:
Last edit: 23 Oct 2019 08:35 by daveo.
  • daveo
  • Premium Member
  • Premium Member
Re: Top-End Redo
24 Oct 2019 09:44 - 24 Oct 2019 09:46
#812944
Looks like there might be room for bigger cams too! :woohoo:
Last edit: 24 Oct 2019 09:46 by daveo.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Top-End Redo
24 Oct 2019 10:55
#812946
That's great. I wonder what the compression ratio is now. Can you show a pic of the cross hatch?
  • daveo
  • Premium Member
  • Premium Member
Re: Top-End Redo
24 Oct 2019 16:09 - 24 Oct 2019 16:10
#812958
SWest wrote: That's great. I wonder what the compression ratio is now. Can you show a pic of the cross hatch?
MTC suggested it may be around 10:1
I'd like to use a grease coated OEM paper cam-cover gasket this time, but not sure what grease would be suitable. I do have some wheel bearing grease on-hand.
Best shot I have of the cross-hatch pattern done by Pit Stop Performance:
Note the marker lines where both head gaskets had to be trimmed to fit around the APE studs, and next to the center galley o-ring instead of on top of it...
a real PITA :evil:
Last edit: 24 Oct 2019 16:10 by daveo.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Top-End Redo
24 Oct 2019 18:28
#812968
Doesn't look any more coarse than I was able to get with the 220 stones. Maybe I'm there after all. I didn't open the gasket where the oil passages are when I put them in. I'll do it this time, maybe open the two rear passages as well.
Looking good. B)
